Author Topic: Distributor  (Read 620 times)
Offline 440_72cuda
Distributor
« on: October 22, 2007 - 01:08:15 AM »
I have installed a 440 motor in my car and i need help in hooking up a MSD ignition,MSD  distributor, and blaster 2 coil  correctly
Re: Distributor
« Reply #1 on: October 22, 2007 - 01:50:22 AM »
MSD has wiring diagrams on their site
 Basics are heavy red & black to Battery + & -  terminal
small red to  12v switched wire , there will be a 2 into 1 wire in the msd box of parts , connect the wire into Both the Blue & brown wire at each end of the ballast & connect the red wire from the MSD into the twinned connetor , remove the ballast resister
Orange & black wires to coil , orange to + , blk to -
Green & violet to dist plug
White is not used
 remove & replace the dist care full noting where # 1 ign wire is positioned on the cap & where the rotor is pinted BEfore removing old dist
« Last Edit: October 22, 2007 - 01:53:17 AM by Chryco Psycho »
Offline cudabob496
Re: Distributor
« Reply #2 on: November 10, 2007 - 01:10:37 AM »
I have the exact same car, a 72 340 Cuda with a 440 now, except it was stroked recently to 496. I also have the MSD distributor and 6AL box. I also have a 72 service manual with electrical schematics. Let my know if you have specific questions.
2011 Kawasaki Z1000
Offline 440_72cuda
Re: Distributor
« Reply #3 on: November 10, 2007 - 08:25:01 PM »
ok i got it figured out thanks anyways.  how do you like the 496? and where did you get the service manuals?
Offline cudabob496
Re: Distributor
« Reply #4 on: November 11, 2007 - 12:21:08 AM »
I was so lucky. I'm looking in the classifieds and some older guy was selling an original 72 Chrysler service manual for $15. Covers practically everything. My 440 was getting old after about 10 years, so did a total rebuild back around 2002. Decided to use all the best parts, and stroke it to 496. Also used ported aluminum Stage 6 heads, solid roller cam, lightweight pistons, M1 intake, etc etc. Tranny is a 727 with 3500 stall. I just drive it on the weekends when the weather is nice. Its scary fast when I floor it. Got a 3:91 in the rear with BFG Drag radials. Its been a work in progress every since I got the car in 1991. Thousands of weekend tinkering hours, blood, sweat, tears, pain, money. Always do whatever I can to be faster. Probably not a part that has not been replaced, but still looks pretty much stock. Probably have about 10 afermarket gauges. How do you have your car set up?
« Last Edit: November 11, 2007 - 01:18:00 AM by cudabob496 »
2011 Kawasaki Z1000
