Author Topic: SOLD: Ebody rear sway bar $50  (Read 3193 times)
Offline miketyler
    • www.miketyler.net
« on: October 22, 2007 - 07:29:19 PM »
I hae an OEM sway bar I bought that I need to sell. Am going with a larger aftermarket unit (thanks Brent!) Unit is a little rusty and only includes the bar, and frame bushings. Asking $50 or might trade for other Cuda parts
« Last Edit: November 02, 2007 - 07:20:22 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline wally426ci
    • maryland mopars
Re: FS: Ebody rear sway bar $50
« Reply #1 on: October 22, 2007 - 09:27:19 PM »
Mike, what else is needed for install? does someone sell the mounting hardware? are there any mounting points that need to be added to a non-rear-swaybar car? my car has the front swaybar and i know the lower control arms are different. thats why i ask......
is this straight?  :chatting:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline miketyler
    • www.miketyler.net
« Reply #2 on: October 22, 2007 - 09:34:17 PM »
I never installed it but from the research I gathered I was going to need the two saddle shaped mounts w/bushings for the frame and the endlink bolts with nuts, washers and rubbers like these. My car already has the lower mount brackets located near the spring perches.
« Last Edit: October 22, 2007 - 09:39:23 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline HP2
« Reply #3 on: October 22, 2007 - 10:17:08 PM »
What size is it?
Offline miketyler
    • www.miketyler.net
« Reply #4 on: October 22, 2007 - 10:28:24 PM »
Its under 1.0", I think .80" or .90"
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #5 on: October 24, 2007 - 12:57:29 PM »
anyone?
72' Cuda restomod
70 Mustang Mach 1
Offline wally426ci
    • maryland mopars
« Reply #6 on: October 24, 2007 - 01:05:04 PM »
I dig it but it sounds like i may need different shock mounts? someone said something about it mounting to that plate .....
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline ksierens
    • 70 Challenger Resurrection
« Reply #7 on: October 24, 2007 - 01:28:36 PM »
Actually the plate for the sway bar mounts on top of the spring.  You still use the original shock mounts.
Kurt - SE Michigan
Offline HP2
« Reply #8 on: October 24, 2007 - 01:37:42 PM »
wally426, it looks like you need the frame mount brackets, end links and bushings, and mounting plates. Like ksierens said, the mounting plate is a seperate plate that mounts on top of the spring, under the axle, and does not change the shock bracket.
If wally426 doesn't want it and you don't mind shipping it up north to Colorado, I'll take it.
« Last Edit: October 24, 2007 - 02:16:27 PM by HP2 »
Offline wally426ci
    • maryland mopars
« Reply #9 on: October 24, 2007 - 05:51:10 PM »
thanks HP2; Id get it, but i have alot going on right now and im leaving for Ireland Friday. I never really thought of installing one until i saw this one, but im sure when im ready i'll find one.
 :cheers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline EvilTwinATX
« Reply #10 on: October 24, 2007 - 05:58:30 PM »
firm feel should sell everything you need for a stock mount rear sway bar... including the rear upper leaf spring mounts.
Offline miketyler
    • www.miketyler.net
« Reply #11 on: October 25, 2007 - 06:16:42 AM »
I'd be glad to ship it. I need to get all these extra parts out of my way.   :pullinghair:
72' Cuda restomod
70 Mustang Mach 1
Offline ksierens
« Reply #12 on: October 25, 2007 - 07:27:59 AM »
 :iagree: Their lower plates even looks like the original, but they won't sell them separately.
Kurt - SE Michigan
Offline HP2
« Reply #13 on: October 25, 2007 - 01:44:09 PM »
I'm going to fab up my own adjustable mounts that can alter the arm length, so this is perfect.
I'll take it!  Shipping would be to 80907. PM me and we can work out payment.
Offline miketyler
    • www.miketyler.net
« Reply #14 on: October 25, 2007 - 07:23:56 PM »
great - will put it on my FedEx acct; should get a little break there. Will let you know what it quotes at going FedEx ground.
72' Cuda restomod
70 Mustang Mach 1
