Author Topic: Rear End Numbers  (Read 1960 times)
Offline Black340
  • 1973 challenger 340 4 Speed
Rear End Numbers
« on: October 22, 2007 - 08:27:41 PM »
Can anybody tell me what this numbers represent :clueless:..thank you
Offline 73Chally
Re: Rear End Numbers
« Reply #1 on: October 22, 2007 - 09:59:43 PM »
I don't know a whole lot about these, but I do know the most important number is the 741, which identifies the type of case (as opposed to a 489).  I never can remember which one is considered better than the other, or even what the differences are, but hopefully that's a start for you.
« Reply #2 on: October 23, 2007 - 01:28:26 AM »
741 is the lightest duty center section , with a 1 3/8" pinion , 742 is 1 3/4" & 489 is 1 7/8", 742 is considered the strongest due to better design & parts used
Offline Black340
« Reply #3 on: October 23, 2007 - 11:44:44 AM »
Is That bad?
Offline 73Chally
« Reply #4 on: October 23, 2007 - 01:10:22 PM »
Depends on your motor.  If you're running a stock 318 then it would most likely be fine, but if you're looking more at a 340/360 or big block, then it probably would not stand up to the increased power output.
Offline Black340
« Reply #5 on: October 23, 2007 - 01:36:11 PM »
Holly cow!!! I have a 340 with  4 speed trans..What I can't understand is that that is the original rear end why the factory will place such a combination if like you say will not stand up to the increase power output :clueless:
Offline 73Chally
« Reply #6 on: October 23, 2007 - 01:48:50 PM »
I might be a bit off on my estimations, but thats the general idea.  I guess it might apply more to trucks and towing.
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #7 on: October 23, 2007 - 02:17:27 PM »
I HAVE  a 741 behind a mild 360, no problems.
Offline tactransman
« Reply #8 on: October 23, 2007 - 07:40:22 PM »
Slicks would kill it,you will probably be fine. :grinyes:
Terry-tactransman
Union, Mo.
« Reply #9 on: October 24, 2007 - 01:04:06 AM »
I bet you cannot hurt it , unless you have slicks & traction even behind a big block , generally as long as the tires will spin you will not hurt the diff / gears
