Author Topic: Alternator: single of double pulley?  (Read 1478 times)
Offline burrpenick
« on: October 25, 2007 - 08:29:16 PM »
What should I buy? My car is an original a/c car, but I have removed the outside components. Is there any difference in pulley location on the single pulley model? I still plan to run the triple groove crank pulley.
GEORGE
currently Moparless
Re: Alternator: single of double pulley?
« Reply #1 on: October 25, 2007 - 09:41:59 PM »
the location is the same , if you are only using 1 belt a single or dual pulley works
Offline burrpenick
« Reply #2 on: October 26, 2007 - 08:07:18 AM »
My car is not a restoration etc, so this will be purely a choice I will make out of desire,  but interesting that I was told that all the performance cars (BS23) were equipped with the dual pulley....the guy says they were like a safety to catch a belt that had slipped?
Comments?
GEORGE
currently Moparless
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: October 26, 2007 - 09:42:17 AM »
That way they wouldn't have to make the single pulley :stirpot:          I'm lookling at the March serpentine set up. Pulleys aren't too expensive.  I like aluminum, it's lighter.    IMO get a dual pulley so you can run PS or somethin down the road :dunno:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #4 on: October 26, 2007 - 12:30:13 PM »
Uhhh no , if it was prone to throwing belts they would have changed the design
Offline miketyler
    • www.miketyler.net
« Reply #5 on: October 26, 2007 - 12:39:36 PM »
maybe it was an AC requirement. Didn't all the Ebody AC compressors have dual belt drive?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #6 on: October 26, 2007 - 01:23:55 PM »
yes AC used dual belts
Offline burrpenick
Pulley problems! Re: Alternator: single of double pulley?
« Reply #7 on: October 27, 2007 - 09:43:13 PM »
Got my new 70 and later alt brackets friday, but now the water pump pulley is not lined up with the alt. I was hoping to use my original triple groove a/c crankshaft pulley and it looks like I should be able to but I know that I'll need the deeper upper pulley and will order one monday. I am still running the ps, but that will be on another crank groove by itself.
GEORGE
currently Moparless
« Reply #8 on: October 27, 2007 - 09:45:04 PM »
the water pump is different between A/c & non A/C
Offline burrpenick
« Reply #9 on: October 27, 2007 - 09:49:28 PM »
They didnt ask me that but did mention I got the 8 vane pump unstead of the 6. I didnt think the outside diminsions were different. This pulley thing can be complex, but I'll get er done.
GEORGE
currently Moparless
Offline burrpenick
« Reply #10 on: October 30, 2007 - 11:48:11 AM »
Bouchillion Performance in SC are pretty good. I bought all three: alt bracket/both pulleys. Mixing will not work!
GEORGE
currently Moparless
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #11 on: October 30, 2007 - 12:05:15 PM »
that is not true, only a/c cars had dual pulleys
Comments?
« Reply #12 on: October 31, 2007 - 12:09:49 AM »
6 & 8 vane pumps use the same pulley
