Author Topic: '73 340 shortblock, plus (seperate) set of Magnum heads  (Read 831 times)
Offline moper
« on: October 26, 2007 - 11:44:14 AM »
Items left over from swap meet fodder :
'73 340 shortblock-bored .030 over, Badger stock type cast pistons. Basic stock rebuild. Guessing less than 4000 miles since rebuild. Includes block/rotating assembly, timing cover, balancer and bolt, oil pan(still sealed up...), oil pump drive, cam retainer plate and bolts. NO timing set or camshaft. No heads. Ran good. Needs freeze plugs replaced looking at them from the outside, I would disassemble and inspect it. It's been sitting loosly bagged for a few years and may have some dead creapies in it from that... $800/m.o.
***I have all parts to build a complete engine for you if needed for additional money. 915, 596, 308, Magnum heads available for this***
Magnum V8 heads- Part of a shop's stock I bought when they shut down: completely gone thru but factory stock. Looks like the only things brand new (not refurbished) are the stock valve springs. Heads were magnafluxed, stripped, guides checked, valve job done, decks milled to flatten them, and reassembled. They are ready to bolt on any Magnum or LA hybrid. Pair of heads only, no rockers or pushrods....$500/m.o.
PM me or email Dmador@travelers.com
