Author Topic: Victor Heads and Offset Rockers  (Read 3320 times)
Offline amcmike
« on: October 27, 2007 - 02:47:06 AM »
Edelbrock says their BB Victor heads require offset rocker arms.  All I have found so far are Harland Sharps at $950!  C'mon, there must be a cheaper solution?  These heads are priced nice, give a stock 383 some good compression, and they have a great modern combustion chamber design and spark plug.
I want these heads bad, but another grand?
1970 Challenger
383, 727
moparniac
Re: Victor Heads and Offset Rockers
« Reply #1 on: October 27, 2007 - 09:14:46 AM »
I believe hughes engines sells a cheaper set........CP had to do alot of other work to get the victors to work prpoerly... go with the indy ez's .........  :working: might be hughes engines also....
youll be putting more than another grand in them!!!!
http://www.hughesengines.com/partDetail.asp?partID=12787&eTypeID=14
« Last Edit: October 27, 2007 - 09:40:11 AM by moparniac »
« Reply #2 on: October 27, 2007 - 12:12:23 PM »
Do Not waste your time with the Victors .
 You have been warned
 Use the Indys they will work at least as well & you Will save money by the time you get it running
Offline oldkimmer
« Reply #4 on: October 27, 2007 - 02:38:47 PM »
........R the victors really that much of a PITA?.........Kim..............
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
moparniac
« Reply #5 on: October 27, 2007 - 06:20:53 PM »
Every one I heard says yes... why do you think they are only $150 more than the rpm's ??? The Engine masters challenge with all alot of competitors using them was for boosting sales... yea they make good numbers but the engine masters challenge dont factor cost in of in house porting costs and mods needed done to them...
« Reply #6 on: October 27, 2007 - 09:51:16 PM »
 In my experience Yup they are  :pullinghair:
Offline moper
« Reply #7 on: November 01, 2007 - 01:12:25 PM »
Even the info from Edelbrock is conflicting on how much offset is needed. Some say use a special Victor type..I think that Harland Sharp deal.. SOme say an Indy -1 style rocker will work... I havent tried. I'll use Indy first.
« Reply #8 on: November 01, 2007 - 11:49:06 PM »
I`ll just use indy heads instead next time
Offline dodge freak 2
« Reply #9 on: November 02, 2007 - 11:57:16 AM »
I hear of great story's with Eddy heads.....like a valve sticking in too tight of a guild and the piston smacking it...Kboom...
If you get the Eddy heads, make sure you have a machine shop break it down and check all the specs...I hear there is always machine work that needs to be done to make them right.
Oh, I hear they cast them cheap too....nothing you can do about that part.
« Reply #10 on: November 02, 2007 - 12:15:28 PM »
Iknow when I port them the cutter will clog so the alum is softer than other alum heads & intakes I have ported & I do not believe they list a spec for the alum used
Offline moper
« Reply #11 on: November 07, 2007 - 12:34:15 PM »
I dont rockwell test. But the valve jobs/guides on Indys suck just as much. Worse in a lot of cases. But, you can buy valvetrains for them...lol. The RPMs will handle an aweful lot of power. The VIctors are more of a race head anyway. So I use RPMs for most stuff, and jump up to Indy if the RPMs can't do what i need.
Offline amcmike
« Reply #12 on: November 07, 2007 - 04:39:22 PM »
Wow, this is the first time I've heard complaints about Edelbrock heads!  Definitely good food for thought.  Thanks.
1970 Challenger
383, 727
Offline moper
« Reply #13 on: November 08, 2007 - 12:38:09 PM »
Not complaints, just reality if one takes the time to look. They are still a great bang for the buck.
Offline amcmike
« Reply #14 on: November 16, 2007 - 12:22:32 PM »
So as far as aluminum heads that don't require offset rockers or special headers and are priced under $2k are the Edel RPMs the best choice?
1970 Challenger
383, 727
