Author Topic: Special tool to remove u-joint?  (Read 1333 times)
Offline 71chmark
« on: October 27, 2007 - 02:34:24 PM »
advice on how to remove clips on u-joint to get it off the driveshaft?
I may be schizophrenic,
Offline GoodysGotaCuda
Re: Special tool to remove u-joint?
« Reply #1 on: October 27, 2007 - 02:49:13 PM »
You can usually use a screwdrive on each end of the open part of the clip and push it off. Then you'll need to hammer the caps out, kind of a trick to doing it if you've never done it. Just whatever you do, dont smack the welds, the tube, or vice the tube, drop it, or anything...you'll create a vibration.
Easy on installing the new ones, those needle bearings can get away from ya.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 74 340 4speed
« Reply #2 on: November 03, 2007 - 11:16:05 PM »
Take the clips out with a flat screwdriver, and find a socket that will go into the holes that hold the u-joint in the drive shaft.  Put it in a vise, with the socket against the u-joint cap and you should be able to compress it enough on both sides remove it.  I have seen some that use a plastic to retain the caps in the driveshaft.  You have to heat these up enough to melt the plastic and break the seal.  The caps fly off, so you have to be EXTREMELY careful when doing this.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline Scatterbrain
  • 1973 Challenger
« Reply #3 on: November 06, 2007 - 09:12:51 AM »
I had to do this on my 71 corvette's half shafts.  Pretty easy with the right tools.  I found a u-joint remover online for about 30 bucks.  Mine were pretty rusted up and my vise couldn't move them.  The u-joint remover looks like a big beefy c-clamp with an open end for the caps to fall through.  It took about 2 minutes to pop off the old u-joints and another minute to put the new ones on.
Offline 71chmark
« Reply #4 on: November 06, 2007 - 04:43:33 PM »
What do you do? Take off the clips, push it through on one side and take a cap off and pull it back through?
  • 1973 Challenger
« Reply #5 on: November 06, 2007 - 06:11:58 PM »
Thats exactly what I did.  Though one was pretty stubborn and I ended up cutting it out with a cutting wheel.
