Author Topic: Brake Booster  (Read 971 times)
Offline Black340
  • 1973 challenger 340 4 Speed
Brake Booster
« on: October 29, 2007 - 05:55:48 PM »
I notice that some times when  I depress the brake pedal I hear  hissing noise that seems to come from under the dash..is that the sign of a power booster punctucre diaphragm :dunno:..is any way to check it before buy a new booster?
Offline GoodysGotaCuda
Re: Brake Booster
« Reply #1 on: October 29, 2007 - 07:30:46 PM »
Sounds like it'd be a booster issue. there are a couple ways to test a booster in the car.
#1, Engine off, depress the pedal a few times until it becomes hard. Hold the pedal down, start the engine. Good operating booster will let your foot travel down slightly once the engine vacuum hits it.
#2, Let it run. Turn off the engine without messing with the brake pedal. Head back in 15 mins or so, if you have a good 2-3 pumps with vacuum assist, your booster is holding. If its rock solid, you got yourself a leaky booster. . . Or check valve
My dads 02 BMW actually was making a hissing sound depending on engine vacuum, louder at idle and decel, replaced the booster and no more.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Brake Booster
« Reply #2 on: October 29, 2007 - 08:21:13 PM »
A bit of a shooosh is normal especially when the motor is not running, it may make some noise when the motor is running but would be drowned out by the exhust.
Re: Brake Booster
« Reply #3 on: October 29, 2007 - 08:22:08 PM »
see if the engine runs differently with the hose to the booster removed & plugged if it does the booster has to be leaking internally
Offline Black340
Re: Brake Booster
« Reply #4 on: October 29, 2007 - 11:06:08 PM »
Thank you :2thumbs:
