The standard BB torsion bars I believe are 0.92" diameter, whereas the Hemi and HD torsion bars are 0.96" diameter. I honestly can't say that you would notice a difference between the two, but since they were the same price I went with the Hemi bars. As far as changes under the hood, that's the beauty of the E bodies. All years were built with the same K frame for all V8's, except for the Hemi, so since it was originally a 318, all you need to drop in the 440 is big block motor mounts, which will run anywhere from $50 to $200 depending on the the type of rubber or poly used on the mount. Other than that, you will want to upgrade to at least a 3/8" fuel line, which will require a 3/8 sending unit, and also you will want to go with a 2-1/2" exhaust. Other than that, you just need a transmission and you're good to go.
