Author Topic: MP Viscous Fan Package  (Read 6072 times)
Offline LAA66
« on: November 02, 2007 - 09:33:51 AM »
 Does anyone have an opinion or experience with the Mopar Performance Viscous Fan Package? I have a flex fan on my small block now and would like to get a more stock appearance. They (Jeg's) claim up to a 15 HP increase over the flex to boot.
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_746971_-1_11207
 On a side note, since MP has no warranty when purchased direct, do companies like Jeg's and Summit sell MP parts "as is" also?
Offline Aussie Challenger
Re: MP Viscous Fan Package
« Reply #1 on: November 02, 2007 - 10:13:01 AM »
  My small block has a flex fan fitted, however the engine temp went up in the desert in Arizona at very slow speeds. No problem at cruising speeds.
  I have already bought a MP Viscous Fan as it should draw more air in at lower speeds and at higher engine speeds reduce the HP drain on the motor and also remove the loading on the water pump.
  According to my parts book the Hemi uses the same Viscous Fan as the small block.  :2thumbs:   :cooldancing:
« Reply #2 on: November 02, 2007 - 11:13:10 AM »
Flex-a-lite has a better 6 blade clutch fan & you can buy the clutch anywhere including Flex-a-lite , , I would get the temperature snsitive clutch Not the rpm clutch , probably will work out cheaper them the Mopar & with a warranty + mthe Mopar unit is only 5 blade
Offline LAA66
« Reply #3 on: November 02, 2007 - 11:25:04 AM »
 Found the Flex-a-lite on the Summit site. 15"-20" diameter with clockwise or counterclockwise rotation. Trying not to seem too lazy but which one would be used in a 70 Challenger?
http://store.summitracing.com/partdetail.asp?part=FLX%2D5655&view=64&N=700+400226+4294887720+4294908110+4294908104+4294840100+4294925081
Offline dodge freak 2
« Reply #4 on: November 02, 2007 - 11:51:07 AM »
If you have the cash, a dual electric fan is the best for saving engine power. Most new cars have that set up.
Depending on where you live you might get away with 1 fan but not too often. Duals are the best but the nice ones that have a shoud around them are over $200, maybe $300 now of days.
« Reply #5 on: November 02, 2007 - 12:12:17 PM »
18" clockwise rotation is what a Chall would have
 as for the electric fans I have found they are far less efficient than a good clutch fan , I have removed electrics & installd clutch fans to solve heating issues int he past
Offline LAA66
« Reply #6 on: November 02, 2007 - 12:22:04 PM »
 Thanks for the info dodge freak 2 sounds like the electric fan is a good setup for racing.  My goal is to get back to the stock appearance though. The claim of an extra 15 hp was kind of a bonus.
Thanks Chryco. I would bet the MP clutch fan is the same as a flex-a-lite just the number of blades would be different. I assume a 6 blade was the original fan configuration? What would be the reason/benefit for 5?
« Last Edit: November 02, 2007 - 12:27:34 PM by LAA66 »
« Reply #7 on: November 02, 2007 - 02:12:45 PM »
15 hp may be an optimistic claim. I think one of the mopar rags did a test on these a couple years ago and on a mild 440, the difference was maybe 8-10 hp. The advantage of the mopar unit is it is a thermostatically coupled clutch, so its speed can vary based on temp and/or engine speed. You could also pick up the clutch unit at most parts stores if you already have a fan for it.
Same deal on windage trays. They work, but the benefit is typically at higher rpm ranges.
« Reply #8 on: November 03, 2007 - 02:19:21 AM »
7 blade si stock , I have not found a repop of the 7 blade though , I have sucessfully trimmed down the larger C body 7 blade fans & used them but you have to be extremely careful to cut the same amount of each blade or it will be unbalanced & fail
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #9 on: November 03, 2007 - 07:54:37 PM »
I am not trying to hi-jack the thread, but if I just needed a new clutch and wanted to keep the original fan, would the Flex-a-lite fit like a stock replacement?
Offline ksierens
    • 70 Challenger Resurrection
« Reply #10 on: November 03, 2007 - 08:08:00 PM »
I think the new 5 bladed fans currently sold by Mopar were found to be more efficient than the old 7 blades.
Kurt - SE Michigan
« Reply #11 on: November 03, 2007 - 10:13:01 PM »
the FLEX A LITE clutch should fit perfectly , oir you could just buy the clutch locally
 I have not heard anything about the efficency oif the 5 blade vs the 7 blade but they do not look right
Offline 74 340 4speed
« Reply #12 on: November 03, 2007 - 10:58:29 PM »
I got my mopar performance viscous clutch fan package from jegs.  I switched from a stock, non-clutch type 4 blade fan to the viscous fan, and I noticed better cooling before I did my other cooling system upgrades.  Car felt like it had more pull in the higher rpms too (car has a well built 340).   Afterwards, I also upgraded to a mopar performance 6 blade impeller wp, and a 22" custom mancini racing aluminum radiator, and it never goes over 180*  The car does not have a shroud.
« Last Edit: November 03, 2007 - 11:01:24 PM by 74 340 4speed »
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
« Reply #13 on: November 04, 2007 - 01:33:27 AM »
Get a shroud, it works much better with one and its very risky not to have one on there. Just think if your girl friend or some other lady was looking at your motor with the hood up and running and her long hair got caught in it...
« Last Edit: November 04, 2007 - 01:41:45 AM by dodge freak 2 »
« Reply #14 on: November 04, 2007 - 09:33:30 PM »
I had the rad buttoned up when it was still in the low 90s here in Georgia, and humid to boot.  The car never went over 180*.  I see your point, but I really don't see a need for a shroud at this time.  I may install one just for appearance reasons when the car is getting closer to completion.  They look better with a shroud.
Andy
