Author Topic: Wiper Motor Restoration  (Read 8312 times)
Offline FY1Cuda
Re: Wiper Motor Restoration
« Reply #15 on: November 11, 2007 - 12:26:00 PM »
If you want to take that barrel off, it's not too difficult to get it back on again.  When you undo the two screws at the end and pull off the end piece the two brushes will spring toward the center.  A good way of reassembling the motor is to slide the spring-loaded brushes all the way into their carriers and secure them with a long, skinny strip of masking tape.  When you put end piece back over the shaft , the tape is holding the brushes out of the way. And then when you get the commutator (copper segmented ring) between the brushes, you can loosen the tape and pull it out, allowing the brushes to spring against the commutator.
Probably the harder part of all this is to get the two windings out of the barrel.  They are held in place by those big screws in the middle of the barrel, and those screws are usually rusted tight.  So if you're going that far, you might have to be prepared to drill them out and repace them with others (1/4" countersink heads, I think) Good luck.  Let us know what you ended up doing.
Offline wally426ci
    • maryland mopars
« Reply #16 on: November 11, 2007 - 03:09:26 PM »
I used the same paint as FY1 did, and Im quite happy with it. after that i cleared the whole motor and used a
"liquid electrical tape" from Home Depot. Mix red and black until you get a good deep red. Im speeking from experience when i say, if it aint broke dont fix it!! if you're not looking for concourse but want it to look nice, tape off the barrel and paint it up. these motors are fragile!  :poopoke:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
