Author Topic: Exhaust System  (Read 606 times)
Offline trouble
Exhaust System
« on: November 04, 2007 - 12:29:01 PM »
I am in the process of ordering my dual exhaust from Accurate.
Does anyone have pictures of the underneath of their car with the exhaust system, and the heat shields that go above the mufflers?
Also how do the heat shield mount, and do any of the brackets go through your trunk.
Offline cudabob496
Re: Exhaust System
« Reply #1 on: November 10, 2007 - 01:07:39 AM »
On my 72 Cuda, the heat shields mount under the trunk. Three bolts hold each of them. The bolts do not go through the trunk floor.
2011 Kawasaki Z1000
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Exhaust System
« Reply #2 on: November 10, 2007 - 10:20:08 AM »
Is this on a Challenger or Cuda?  Not too sure if ti makes a difference, though, but......
I'll have to look under my car, kinda busy today though...I seem to remember on my '72 Challenger, there may be upwards of 5 mounting bolts.  2 up to the trunk, 2 to the frame rail, and 1 on the crossmember for the shock.
Here's a pic I found on the net.. http://web.mac.com/khansen6/iWeb/Site/Exhaust.html   Look at the top right pic.  It looks like it had 2 tangs going up to the trunk.
Here's another pic from Ebay... There are 2 holes on a lip that goes the lenth of the shield that mounts to the rear frame rail that is hard to see.  Again, I could be wrong, will need 2nd opinion...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=280171986486
