LED lights for brake, tail and turn signals
Author Topic: LED lights for brake, tail and turn signals  (Read 4047 times)
Offline Ornamental
  • Oslo, Norway
Re: LED lights for brake, tail and turn signals
« Reply #15 on: January 13, 2008 - 05:24:18 PM »
Got my rear light LED's at hitechledproducts.com
How they look.
http://www.cuda-challenger.com/cc/index.php?topic=31935.msg337191#msg337191
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline 73EStroker
« Reply #16 on: January 14, 2008 - 01:54:03 PM »
Cudagirl - the reason your LEDs did not flash is they draw less current than the standard incandescent bulbs. The extra current is needed to make the flasher work as it works on a current draw (makes heat) thing. Use an electronic flasher unit that plugs straight into the old connector for the existing flasher. Someone mentioned the electronic unit here in this thread.
Barry (Salmon Arm)
Offline 426HEMI
« Reply #17 on: January 14, 2008 - 02:12:23 PM »
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #18 on: January 15, 2008 - 04:38:51 AM »
It is a 4 pin flasher in my car i dont see any on any site i need to know where to get one.
Offline gomopar440
« Reply #19 on: February 07, 2008 - 12:53:58 PM »
Working on motorcycles I've swapped bunches of lights with LED's. The easiest way I've overcome the slow or no blinking issue was to replace the stock flasher relay with a Tridon (brand) EL-12 (model#) flasher. They're available at most auto parts chain stores. It's a completely digital relay and is not load dependant. :2cents:
Offline burnt orange
Offline miketyler
    • www.miketyler.net
« Reply #21 on: February 22, 2008 - 06:36:35 AM »
yup - lemme know if anyone trys this. I still am thinking you will need one that has LED's on the top and sides for full illumination.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #22 on: February 22, 2008 - 09:23:04 AM »
flashers are 2 pin not 4 the 4 pin is something else like the horn relay
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #23 on: February 22, 2008 - 10:49:32 AM »
 :popcorn:
Offline drewcrane
« Reply #24 on: February 25, 2008 - 07:32:28 AM »
using LED's would require wiring a relay in the circuit, right?
I would be willing to try these.... heck... I have already WAY blown my budget - what's a bit more $$.   :faint:
yea i dont have a budget either, i lost it when i bought the car :dogpile: :bananasmi
Offline gomopar440
« Reply #25 on: March 04, 2008 - 10:46:03 PM »
Like I said. Been there, done that. 360* LED bulbs here ---> http://superlumination.com/194.htm
I've used this style of LED's on a number of projects no problemo. Shop around the site, I know they have some with the 1156 and 1157 style sockets in there. You might even be able to find the small dash bulbs as well if you want.
The EL-12 flasher relay is a 2 pronger BTW.
