Well Mopar Stage 5 heads are cheap & will out flow production heads But they have the open chamber whih I dislike unless you use a quench dome piston with them
I Know Indy has an Iron version of at least 1 head , the SR I believe , Possibly the EZ as well , probably the best choice for performance
the best choice for production heads IMO is the 915 or the 516 with the closed chamber , ported & with larger valves
,any of the production open chamber heads will work But i would use a quench dome piston to kill detonation
