Author Topic: striped header bolt  (Read 851 times)
Offline CUDA JAS
  • vroooooom!
striped header bolt
« on: November 07, 2007 - 09:03:17 PM »
I seemed to have striped a header bolt hole on my 360.
What is the best way to fix this.
Can I use a studs to fix the problem?
thx
Jas
74 'cuda 360/727
Just call me a gearhead!
Offline bb71challenger
Re: striped header bolt
« Reply #1 on: November 07, 2007 - 10:26:34 PM »
you can try studs but the best way is to just helicoil it.
*Brett*
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: November 07, 2007 - 10:43:02 PM »
Put a helicoil in it and then use a stud. Even though the helicoil should fix the problem, if you also use a stud you won't have to worry about the helicoil coming out or being damaged by installing and removing a bolt over and over.
1996 Dodge Viper GTS Coupe
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: November 08, 2007 - 08:04:31 AM »
where is the best place to buy helicoils?
74 'cuda 360/727
« Reply #4 on: November 08, 2007 - 12:07:16 PM »
Hard to say what is local to you but most good parts stroes will sell the kits or tool stores should also have them
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: November 08, 2007 - 02:57:19 PM »
cool, i will check it out :2thumbs:
74 'cuda 360/727
Offline Scatterbrain
  • 1973 Challenger
« Reply #6 on: November 08, 2007 - 03:07:06 PM »
I picked some up at Orielly's.  Its actually not hard to do, though I recommend a good drill, something that can go slow with lots of torque.  Also, make sure to drill at the correct angle, it helps to have a spotter.
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: November 08, 2007 - 03:10:59 PM »
Did you do it in the car or our of the car?
74 'cuda 360/727
  • 1973 Challenger
« Reply #8 on: November 08, 2007 - 05:03:49 PM »
Out.  It was a 454 that was going in my vette.  It was still on the engine stand when I found out that 4 of the bolt holes were stripped on the left cylinder.  These were the top holes for the intake manifold.  I also recommend putting a big goop of vaseline on the bit to catch any metal filings.
Offline Robb
« Reply #9 on: November 08, 2007 - 10:54:54 PM »
ACE hardware has them too (helicoil).    youll need a drillbit, a tap and a helicoil, and a stud or a new bolt.     Its gonna cost around 40 - 50$ from ACE.  IIRC.  If you can do it in the car, great if your lucky.    on a 383 I couldnt do it without pulling the head.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
« Reply #10 on: November 08, 2007 - 11:08:09 PM »
Any chance of taking out the motor mount bolts on one or both sides and jacking the engine up enough to do the job? I would sure give that a shot before pulling the head. Just 2 through bolts and its ready to go.
*Brett*
Offline dodge freak 2
« Reply #11 on: November 09, 2007 - 05:07:25 PM »
Heck I would think about pulling the wheel well and or fender off, before the head.
Guess it depends which bolt, some would be easy, others a pain.
You might get away with just taking the tire off and working from there. Believe thats how you change some spark plugs on these new cars
Offline ntstlgl1970
  • T a c o c a t
« Reply #12 on: November 10, 2007 - 12:53:52 PM »
Getting the hole drilled straight is the most important part, also when you get to the point of installing the helicoil, make sure you thread it in about 1/2 a turn past flush, then take a center punch and smash the lead in thread (in the cast iron) behind the helicoil so it can't back out. And don't forget to take a punch and break the "tab" off the end of the helicoil where the tool grabs it so if you install a bolt/stud that is too long, it doesn't try to continue to thread the helicoil too far.
