Author Topic: How is the cable supposed to hook on the water valve?  (Read 1475 times)
Offline covert
« on: November 07, 2007 - 11:28:43 PM »
Now that its getting cold, I guess I need to fix this:
How exactly is the temperature control cable supposed to connect to the water valve?  My 73 barracuda has AC, and sometime in the past, the previous owner decided to just try to wrap the cable around the post on the water valve.
There's probably some kind of clip or such.  Does anyone have a idea where I could get one or part numbers?
Thanks,
Covert
Re: How is the cable supposed to hook on the water valve?
« Reply #1 on: November 07, 2007 - 11:57:42 PM »
« Reply #2 on: November 09, 2007 - 03:06:07 AM »
I know that clip is used for the heater box cables but on the valve underhood it is different
Offline farmboy70
« Reply #3 on: November 11, 2007 - 12:41:44 PM »
This is a picture of a 71 water valve, you can see a "V" shaped clip that holds the cable. You press the cable down into several barbs in the V.
Offline miketyler
    • www.miketyler.net
« Reply #4 on: December 10, 2007 - 06:59:00 AM »
I need one of those too, the one in the lower pic is correct for my car. Where can we get them?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #5 on: December 10, 2007 - 10:30:45 AM »
Its a hard clip to find. I just saw them on E bay a week ago. The V has a notched area inside that the cable slips into and holds it.
The one below could work but it wasn't the exact one.
http://www.rtspecialties.net/proddetail.asp?prod=6015143
Offline miketyler
    • www.miketyler.net
« Reply #6 on: December 10, 2007 - 10:42:14 AM »
that one looks like the cable is situated 90degrees from the retaining clip. I'll have to revisit mine but I think the cable should be in line with the retaining tab.
72' Cuda restomod
70 Mustang Mach 1
