Author Topic: Choosing a new cam-shaft..???  (Read 1572 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: November 09, 2007 - 11:29:40 AM »
I want to make my Barracude more streetable..
What kind of camshaft should I go for..???
Rigth now I got:
crane Rollercam  DUR 0.50  272   lift  ,625
470Cui. 383 stroker..
IndyHeads  440-1
Flattop pistons comp  11.4
NOT good on the street... :pullinghair:
« Last Edit: November 09, 2007 - 11:34:11 AM by cowboy »
Offline cudagirl4406pk
    • Garageartmusclecars
Re: Choosing a new cam-shaft..???
« Reply #1 on: November 09, 2007 - 03:52:03 PM »
Go with a 509 purple stick camshaft nice for the street and plenty of power
Offline matt63
« Reply #2 on: November 09, 2007 - 04:09:35 PM »
I think the 509 has about 248 duration @0.050 which wouldn't be crazy in a 470 but you might as well look for roller cams.  I would contact Hughes Engines or perhaps Comp Cams for help.  When I contacted Crane for my small block stroker they recommended a much more aggressive cam than Hughes.  I was happy with the Hughes selection.
Matt in Edmonton
'68 Valiant
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: November 09, 2007 - 06:38:07 PM »
OK, - this "509" is that the lift..??? And is it a hydralic cam..???
In the good old days, I run an original 440/6pack hyd. cam, Perfect, at that time..
It was a 308* - What would that be in todays 0.050 mess, and how much lift did it have..???
« Reply #4 on: November 09, 2007 - 06:48:01 PM »
Yes 509 is the lift i have it in my 4406pk cuda and the motor dyno'd at 492hp at the flywheel.
Offline matt63
« Reply #5 on: November 09, 2007 - 07:38:59 PM »
308 would be the advertised duration.  The duration @ 0.050" would be less.  You can't tell what the other specs would be exactly without finding the cam card or the cam number and going back to the mfg.  This would not have been a mild cam - strip only.  The Mopar 509 cam is a hydraulic flat tappet cam.
Matt in Edmonton
'68 Valiant
moparniac
« Reply #6 on: November 09, 2007 - 07:40:53 PM »
personally I think the mopar solid .528 lift cam is the best for the street... low duration and wide centerline 114*
440-1 are more of a track head...
 :working:
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #7 on: November 09, 2007 - 07:51:00 PM »
Anybody got the spec. for an all original 440/6pack cam..???
Offline Oldschool
  • Member Since 9-05-06
« Reply #8 on: November 09, 2007 - 07:54:00 PM »
Be sure you don't go too small with the cam selection.  That stroker needs a little bit of a cam in order to feed those deep cylinders......     :cheers:
Ken  --  In Georgia
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #9 on: November 09, 2007 - 07:56:54 PM »
Got you, - thats why I'm Concerned about the 509 purple... :clueless:
Offline dodge freak 2
« Reply #10 on: November 09, 2007 - 08:17:36 PM »
Problem with going off a old cam that was made 20+ years ago is even if its called the same now, like Comps 280, is the grind is a bit diff. now than 20+ years ago.
Even saids it somewhere on their web site, we are always upgrading the cam grinds for todays tech. Or something like that.
Who built the motor ? Maybe ask the builder if you can.
« Reply #11 on: November 10, 2007 - 02:39:16 AM »
 :working:
I like this cam with 1.6 ratio rockers ,
What do you want , personally I perfer the solid grinds over Hydraulics , I use a lot of custom ground Lunati cams in the .570 lift range with 240* @.050 , they idle well & make a Lot of power & vacuum , I can get you specs to order one if needed , Engle cams also has similar grinds available in the KV series
Offline matt63
« Reply #12 on: November 10, 2007 - 10:37:56 AM »
Too small for a 470 stroker.
Matt in Edmonton
'68 Valiant
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #13 on: November 10, 2007 - 04:27:48 PM »
Yeaaahhh, but I really wanna know the spec...???
« Reply #14 on: November 11, 2007 - 03:18:10 AM »
it is in the FSM but i do not have mine handy right now the lift is pathetic at around .450
