Author Topic: How far ?  (Read 777 times)
Offline IMNCARN82
  • LeDZeP
How far ?
« on: November 10, 2007 - 09:49:33 AM »
I'm looking into re-building this 340. If I have a valve job done,should I replace the piston rings?   :working:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Re: How far ?
« Reply #1 on: November 10, 2007 - 10:02:58 AM »
I guess it depends on how old the engine is but generally yes replace them , you do have to at least hone the cylinders to get the correct finish in the bores though so the rings will seat in
Offline IMNCARN82
  • LeDZeP
Re: How far ?
« Reply #2 on: November 10, 2007 - 10:18:52 AM »
Thanks CP ,that's what I figured.  This engine probably has 50K on it. The reason I consider the valve job is there's alot of carbon build up in the exhaust ports on the heads.Alot.  She would smoke some on start up,only sometimes.Probably valve seals?  When I replace the lifters do I have to change out the cam?   Do I just re-build the whole engine? :clueless:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Re: How far ?
« Reply #3 on: November 11, 2007 - 02:56:05 AM »
Carbon could be intake leak , valve seals / guides or just fuel
You can use new lifers on an old Cam If you like the cam although more modern grinds may be a benefit , what is in there now
Rebuilding the whole engine definatly makes sense , it is a lot more work to redo it again later , this doen`t mean every parts need to be replacd but it should be clean & checked before reusing any part
