I'd check the bulkhead connections, connections at the v/r, field connections at the alt. If all that seems good, i'd suspect a v/r myself. And if you've yet to change it, it won't hurt to have a back up! DAMHIK
i ended up running my v/r off a relay instead of through the stock wiring and have seen a little more steady charging over stock.
