Author Topic: Spacers on a single plane intake  (Read 1498 times)
Offline dodge freak 2
« on: November 16, 2007 - 05:28:43 PM »
Whats the pros and cons on spacers on a open single plane intake ?
Seems like I just hear about using them on a dual plane intake to increase rpms.
I am using a holley non egr street dominator intake on a SB and its fairly low, I have some room for a 1/2" maybe a 1" spacer. What is the thinking about what happens. Seems to me by raising the carb, it slow the flow down. That be no good right ? I believe 4 hole spacers are to help the low end but it seems fine. I am thinking of an open spacer.
Re: Spacers on a single plane intake
« Reply #1 on: November 16, 2007 - 06:53:19 PM »
The one nice goodie about a spacer is it's a plus at preventing vapor lock since you raise the carb off the hot intake.  :thumbsup:
I would stay with an open spacer. I have the same intake on my big-block. It didn't run as well with the 4-hole spacer(I experimented  :misbehaving: ).
« Reply #2 on: November 16, 2007 - 07:42:59 PM »
an open spacer will increase the plenum volume which will generally help with mid to high rpm power , why not try it
Offline cudabob496
« Reply #3 on: November 17, 2007 - 03:12:48 AM »
In my opinion, generally only a benefit in high rpm engines, but many times they can hurt perfromance as well as improve it. Just got to experiment. I did however machine my single plane down a bit to use a spacer to keep the carb cool, while still having enough hood clearance.
2011 Kawasaki Z1000
« Reply #4 on: November 17, 2007 - 03:20:21 AM »
The SD is a relatively small plenum intake which is great for hood clearance so adding plenum on the SD should help but not always
Offline cudabob496
« Reply #5 on: November 17, 2007 - 07:46:43 PM »
Seems like in your case it could help. Will keep carb cooler, and will increase plenum volume to provide more top end power. Raising the carb should increase flow I would think, and make the flow more laminar (thus the power increase at high rpm). All depends at what rpm we want to make power.
2011 Kawasaki Z1000
