Author Topic: Deep Groove Pulleys  (Read 1067 times)
Offline RusTy/SE
  • Just havin' fun
Deep Groove Pulleys
« on: November 17, 2007 - 09:02:11 AM »
Have deep groove pulleys ever been manufactured for Mopars? I happened accross todays episode of Dream Car Garage as they showed a comparison shot of a deep groove vs normal shallow groove. BIG difference as the belt sat nearly 1/4" below the pulley lip :thumbsup:
Russ :working:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline cudabob496
Re: Deep Groove Pulleys
« Reply #1 on: November 17, 2007 - 07:39:54 PM »
Out of curiosity, what would be the need of deep grove pulleys if the belt is tensioned properly. Belts don't normally leap out of a normal pulley, do they?
2011 Kawasaki Z1000
Offline dodge freak 2
« Reply #2 on: November 17, 2007 - 09:28:08 PM »
Was thinking of the same thing, only time I seen belts jump off on a Mopar is when the pulleys are not even with each other.
Offline RusTy/SE
  • Just havin' fun
« Reply #3 on: November 17, 2007 - 11:03:32 PM »
 :iagree:  Same here, just wondering  :dunno:
Russ
2001 Durango     1B4HS
« Reply #4 on: November 18, 2007 - 02:12:41 AM »
My duster used to toss the belt regularly while racing it at up to 7200 rpm , I used an idler to keep the belt on , there are companies that make custom pulleys so it would be no problem to get them , the big issue is the crank & water pump pulley almost touch now with stock pulleys so the pulley would have to be wider to accomadate the extra depth of the groove
Offline cudabob496
« Reply #5 on: November 18, 2007 - 02:16:04 AM »
What kind of valve train did you have that allowed revving over 7000 rpm?
2011 Kawasaki Z1000
« Reply #6 on: November 18, 2007 - 02:28:34 AM »
Mopar .590 cam , 3/8 chrome moly pushrods , Crane ductile rockers, Stainless valves ,10* superlocks & retainers & I can`t remember which springs I used
Offline cudabob496
« Reply #7 on: November 18, 2007 - 04:02:40 AM »
Must have been some serious springs!
2011 Kawasaki Z1000
