Author Topic: cuda construction  (Read 2544 times)
Offline 4Cruizn
  • HEMI FISH
cuda construction
« on: January 26, 2004 - 03:53:58 PM »
OK now that I have my new cuda convert. home and ready for re-construction, a plan is needed!  My buddy asked the other day . . "what the plan?"  "Where do we start"??  Now to paint this picture alittle more, the car has been in the body shop for the last 3 years getting all the nessesary work to make this car as solid as I could get it. After stripping everything out of the car including dash, convert. top and all glass, the shell was taken to a media blasting shop in Detroit so that I could have the body stripped.  I tell you, that car came out of that shop one silver piece of metal. (can you say "Naked Cuda") Any work that needed to be done could easily be seen.  Since this car spent some time in Florida, quite a bit of repair was needed including truck, front floors, quarters, trunk ext. and some spots in the rear tailpanel.  Also where the water sits at the back of the convertible top needed attention.  OK so all this work is completed and a beautiful coat of a purple that I mixed at the paint store is applied!  (no name for the paint, special mix but in the computer if I need more) The car comes home finally after a few years.  I think I actually went a year and half without even seeing my car.  So the car is now home and the k-frame is all new and beautiful with all poly bushings Its installed already so I have a rolling shell all new ready for assembly!
While the car was in the body shop, I spent the time aquiring parts of course.  New parts are as follows:
1970 440 4 barrel completely rebuilt new
727 trans completely rebuilt new
New gas tank and stainless pre-bent lines
New glass all around
All body parts are here and painted plus I have a beautiful grill with all the stainless and buckets,
new seats, door panels carpet & convert. top w/ glass
All new wiring harnesses complete including road lamps
The dash completely gone through be me, I even reset the odometer to 00000 so I can start new.  I have a new brake booster, wiper motor, blower motor, complete gasket set, firewall gasket set, rubber bumpers and the list goes on.  Some part are still needed but I'm working on that. So back to the question on order of assembly?? I think the firewall is the place to start because it will be the hardest to get at when the motor goes in, and I think the dash and steering assembly should be close to the front of the list since the steering wheel goes through the firewall. Is it easier to install the dash before the steering assembly??  So if I complete the firewall and install the dash . . . then I think I should go right to the motor and trans!  :D   With the motor and trans in, I can install wiring and fuel lines?  Do you think I should run fuel and brake lines before the motor and trans? So lets say I make to this point and my car is now close to starting!  My attention would be on all systems to make the car run. Once I get it to run and move, I can start to install glass body markers and the new interior.  I still need to find shaker parts but will probably buy an aftermarket kit. I know they're available at I think Ben snoker or something like that in California.  I also still need a steering wheel but I might buy something custom?? Don't know yet. I was able to aquire alot of parts for the dash and interior from a smashed Challenger that we bought at auction.  It was smashed on the drivers side. I was told a car crossed the x-way and hit it, but the car was a nice show car before that.   Oh here is a picture of my spare bedroom, it was the safest place for parts!  Love that shaker hood!  Any help on process will be appreciated!  Thanks Everyone!  8)
[attachment deleted by admin]
lemonboy69
Re:cuda construction
« Reply #1 on: January 26, 2004 - 04:07:52 PM »
I think you got your plans pretty well straight... but I would lay the fuel and brake lines in well before the engine is in... only because it's going to be a pain to work around the master cylinder with the 440 sitting in your way... ::) just a suggestion... but other then that, HOPE TO SEE THIS BAD GIRL AT CARLISLE!!! :D ;D
LB
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #2 on: January 26, 2004 - 04:21:04 PM »
4Cruzin...my husband and I have struggled with this same thing.  This is the first car we have ever put together, so none of this is second nature to us.  We are just a step ahead of you in the process.  Our plan, though kind of vague at this point, is...
Engine (already on k-frame)
transmission (waiting on torque converter)
rear end
drive shaft
front suspension
gas tank
gas lines
brakes
brake lines
starter
a/c
radiator
not exactly sure when we want to do the exhaust...but around here somewhere
then we'll do the firewall stuff
dash
electrical
interior
vinyl top
windows
body (doors, fenders, hood, trunk)
I know I'm leaving a bunch of stuff off, but this is the plan we have in our heads...probably wouldn't hurt to write this stuff out.
If anyone sees an error in our logic, would love to hear about it.
lemonboy69
« Reply #3 on: January 26, 2004 - 04:36:42 PM »
Rev... you gonna do the rear suspension at the same time as the front... or during the rear axle?? I know that sounds kind stupid... but you can just throw the axle in and not do the suspension... (figured I should justify my question... lol) ::)
LB
Offline Rev-It-Up
  • Global Moderator
« Reply #4 on: January 26, 2004 - 04:49:43 PM »
Sorry, that was probably unclear.  Our rear-end is already put together (just took it off to re-clean and paint the underneath of the car).  All we have to do is re-attach the leaf spring shackles to the car and that's done (or will be done tonight).  Is that as clear as mud?
lemonboy69
« Reply #5 on: January 26, 2004 - 04:54:38 PM »
Man I wish I had as much time as you do to work on your baby.... ::) ::)
LB
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #6 on: January 26, 2004 - 06:42:25 PM »
As you can see with both of you making a list of to do mini projects helps to keep you from having to "undo" something because of complicating procedure. Some things are quite logical, others it may not matter so much.?  But with the two projects that I have done two things stand out in memory: dash before glass, and the rest of the interior is last. And as LB suggested, brake, tranny, and gas lines before any suspension or drive train, just easier and a "cleaner" work area to work around. Fun isn't it? But even more exciting to one day realize, this baby is soon going to be running and moving! And MoparMan who just finished his beautiful project can give you some direction, it's still fresh in his mind I'm sure. Happy for you guys, just be patient, --easy for me to say right,?
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline 4Cruizn
  • HEMI FISH
« Reply #7 on: January 26, 2004 - 08:53:05 PM »
Ok sounds like I now have a plan on what to tackle next!  Rev your gonna put your engine in from the bottom up I assume thats why its on the K-frame already  :D  I think I'm going in from the top and then install the trans from the bottom.
lemonboy69
« Reply #8 on: January 26, 2004 - 10:47:16 PM »
No... she dropped it in from the top and I'm assuming she's putting the trans in from the bottom... ::) Rev?
LB
Offline Rev-It-Up
  • Global Moderator
« Reply #9 on: January 26, 2004 - 10:51:12 PM »
Actually we had the k-frame in and just lowered the engine right onto it.  We have the car on blocks right now...perfect height for getting the trans under and lifting that up.
We're taking the advice on getting the brake and gas lines in before rear suspension.  We laid the front to back gas and brake lines in tonight, but need to get the line clamps.  They went in pretty good after scratching our heads on some of those bends.  Thanks to MoparMan for all his GREAT resto shots!  They came in handy!!
