So when you start driving, the needle will move from 100MPH down to whatever speed you are driving?
No, its indicating correctly. The pointer end of the needle broke off at the hub. What you see in the illustration is pointing at 0 MPH.
I had exact same thing happen. Most likely it's the bushing in the back of the speedo. Apparently it's a fairly common problem. Mine broke the speedo needle when it happened.
Katfish - Was it the high speed vibration that broke your needle?
Ok, its all apart. Will check the cable. What visible signs should I look for on the speedo head? As far as I can tell, it looks about the same as it did when I took it apart to put the white decals on.
Should there be any lube on the plastic worm and drive gears? Both the needle and drive movements are smooth and neither seem to have any rough spots or unusual friction points. These are pretty simple looking devices, the magnetic primary drive doesn't contact the flywheel anywhere and there is no thrust play to it but there is some on the flywheel. Also the small plastic bushing at the front has a little wear and as a result, the flywheel seems a little sloppy. Should that be a dead-nuts machine fit with zero slop?
