Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Removing steering column
« previous
next »
Print
Pages: [
1
Author
Topic: Removing steering column (Read 749 times)
basement
Jr. Member
on:
November 18, 2007 - 02:08:23 PM »
I read here that you are supposed to removed a drift pin from the steering coupler before attempting to pull the column back out the fire wall. Is this pin solid or hollow, because I can run a small screw driver clear through and out the other side where this pin would normally be? Assuming the pin was never installed then I should be able to pull on that column and walla! But the column won't bulge.
Logged
IMNCARN82
Resident
LeDZeP
Re: Removing steering column
Reply #1 on:
November 18, 2007 - 02:20:21 PM »
It's a roll pin. Hollow. You need something the perfect size to drive it out. It can be a pain. Let it soak in PB or a penetrating oil for a nite. Mine popped right out. The real pain was getting the coupler far enough off.
Logged
'73 340 5 speed,RMS,BAER,... "Supercuda" (O[ ]||||[ ]O)
'69 Dodge Charger 383,Auto (OiiiiiiiiiiIiiiiiiiiiiO)
13' Challenger R/T BlacktoP 6spd. (OO________OO)
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert "cuda bob"
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #2 on:
November 18, 2007 - 02:58:47 PM »
It shouldn't be that bad if you have the right sized punch. In lieu of that, I used an old "T" type of valve cover hold down. The threaded side provided a perfect sized punch.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
basement
Jr. Member
Reply #3 on:
November 19, 2007 - 09:26:17 AM »
Got it, thanks guys. Now that I have the column out I plan on repainting the column covers, do they just slide off after the steering wheel is pulled? Would there be maintenance you'd recommend be done to the column now that it's completely out?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
November 19, 2007 - 12:32:43 PM »
the column needs to be disassembled to getthe housing / cover off , not much to service inside , basicaly just tubes slipped together , you can lube the upper brg & clean & paint all the parts
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
