Author Topic: Need some headers  (Read 1119 times)
Offline common 27
Need some headers
« on: November 19, 2007 - 06:47:03 PM »
I've been looking at all the different headers available and want to know what will fit the best with the edelbrock rpm heads.  thanks all
1970  Challenger Convertible   1968 Satellite Convertible
Offline common 27
Re: Need some headers
« Reply #1 on: November 19, 2007 - 06:50:50 PM »
 I forgot- its a 400.    :dupe:
« Reply #2 on: November 19, 2007 - 06:59:24 PM »
Thanks, but is this for an E-Body car? What is your budget? Many folks look to TTI, but that is high dollar.  :22yikes:
Offline common 27
« Reply #3 on: November 19, 2007 - 09:50:30 PM »
It is for a B body but they take the same header according to the descriptions. I would like to find a pair for under $300. I know the TTi fit good but like you say- high dollar. I am concerned about the heads being a little different than stock.
daves70
« Reply #4 on: November 19, 2007 - 10:00:35 PM »
What a dumb-azz!
Offline common 27
« Reply #5 on: November 19, 2007 - 10:25:49 PM »
 :nono:   no need to be rude
Offline asm74
« Reply #6 on: November 19, 2007 - 11:05:29 PM »
Okayyy... Hopefully I can give you some helpful information, without insulting you.
First, I have nothing like your car.  So what I have to say may easily be debunked.  I have an e-body with a small block engine, magnum heads and a mini starter.  I went with Doug's Headers and haven't regretted it one bit.  The finish was amazing, they have thick flanges (that was very important to me), and the fit was perfect.  I did not have to thread my steering linkage through the pipes or remove my starter, and I have no problems clearing the spark plugs.  Having a gooseneck  ratchet adapter could've helped; the bolts were a bit hard to torque in a few places.  On summit racing I see Doug's makes headers for your application.  I would highly recommend them since they have an easy to install design, look great, and seem to have very good flow characteristics.  The only issue I had was that the reducers that came with them were too small, I wanted 2.5" and they were more like 2".  Check out part DOU-D451 or DOU-D451-R on summitracing.com.
73 Challenger
« Reply #7 on: November 20, 2007 - 02:44:49 AM »
Dougs / Thorley headers would be my second choice , TTI is first , the eddy heads do not seem to alter the fit of a header designed for stock heads , TTi fits so close to the floor they actually have a different header for the B[low deck] & RB [ high deck] blocks
daves70
« Reply #8 on: November 20, 2007 - 10:18:25 PM »
:roflsmiley:HA-HA DUMB-AZZ!!
