Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
s/b 727 kickdown question
« previous
next »
Print
Pages: [
1
Author
Topic: s/b 727 kickdown question (Read 1033 times)
burrpenick
Jr. Member
on:
November 19, 2007 - 07:58:23 PM »
I have a set up that was supposed to be off a 340 e body and it has a pivot that appears to swing on a rod off of the bell housing ( I dont have the rod). A friend tells me that pivot type is the old style and that the E body had on rod that extends from the pivot at the back of the intake all the way down to the lever on the trans. Is that so? Would that rod for the pivot be the same for big or small block (if there is one used that is).
thanks, George
Logged
GEORGE
currently Moparless
Chryco Psycho
Administrator
C-C.com Guru
Re: s/b 727 kickdown question
Reply #1 on:
November 20, 2007 - 02:49:32 AM »
the rod is the same big or small block
either system will work fine , I have seen some early 70 E bodys with the 3 piece system which I also thought was incorrect but the car was very original & unmodified so possibly they did have the 3 piece
Logged
RUSTY Cuda
Sr. Member
One big step foward!
Reply #2 on:
November 20, 2007 - 05:21:02 PM »
Saw this while I was crusin ebay. Rich.
http://cgi.ebay.com/ebaymotors/mopar-727-kickdown-cuda-charger-BB-440-383-challenger_W0QQitemZ290181434753QQcmdZViewItem?hash=item290181434753
Logged
426HEMI
Sr. Resident
My M46 Barracuda! Member Since:October 01, 2005
Reply #3 on:
November 20, 2007 - 05:29:09 PM »
Seems that everyone thinks that the cars were all made the same. When these were put together they used anything that would work and did not care if they were all the same.
Logged
Got a pretty good start on my M46 optioned Barracuda restoration but now it is on hold till I can gather more funds. Still need a few parts for it. SIU Graduate 75 AAS Automotive Tech, 94 BS Advanced Tech Studies, 1997 MSED Workforce Education and Development
1970 M46 Barracuda
1998 Dodge Darango
Gordon
BS23VOB_FJ5_Faker
Guest
Reply #4 on:
November 20, 2007 - 09:51:53 PM »
Both my 70 440 Charger, and my buddies 70 383 Cuda had the 3 piece linkage. I wasn't the original owner, but if they changed out the linkage, thats the only thing they touched on a 30,000 mile car.
Logged
vinb
Resident
Reply #5 on:
November 20, 2007 - 10:41:49 PM »
It sounds like your have a early kickdown set-up. Yes, the '73 car should have only one pivot by the throttle bracket with a long rod down to the trans lever on the valve body. Attached is a photo of the early linkage where their are two pivots (7 )is on the side of the bellhousing portion and (9) up by the throttle brkt.
Last Edit: November 20, 2007 - 10:44:59 PM by vinb
Logged
RusTy/SE
Sr. Resident
Just havin' fun
Reply #6 on:
December 12, 2007 - 07:10:35 PM »
Logged
Russ
2001 Durango 1B4HS
1970 Challenger JS29U
Restoration thread:
http://www.cuda-challenger.com/cc/index.php?topic=27173.0
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
