Author Topic: 383 to 496 combination. What carburetor?  (Read 2052 times)
Re: 383 to 496 combination. What carburetor?
« Reply #15 on: November 22, 2007 - 01:40:30 AM »
i am guessing approx 30-40 RWHP in a 525 hp engine , I have dynoed similar engines & that seems to be the usual spread , altough it is not a straight across comparison as I generally use a different cam grind to enhance performance when I know manifolds are being used so the gap should be wider using the same cam for both
Offline ArcticCuda
    • Pepe
« Reply #16 on: November 22, 2007 - 04:02:34 AM »
Hi CP. What kind of numbers you can see with this combination?
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
