Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
SB/BB cooling fan interchangeability?
« previous
next »
Print
Pages: [
1
Author
Topic: SB/BB cooling fan interchangeability? (Read 605 times)
miketyler
Resident
on:
November 21, 2007 - 08:56:14 AM »
I am considering upgrading my stock 7 blade fixed fan on my 340 to a BB fan with clutch. Are the hub hole patterns the same? The BB fans are a larger diameter and have a greater pitch (so I'm told). Has anyone tried this and realized a noticeable improvement? I would probably have to trim my shroud for the larger diameter and was considering spacing the radiator closer to the fan so I could put a high CFM SPAL pusher up front for aux cooling when I need it.
Logged
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Chryco Psycho
Administrator
C-C.com Guru
Re: SB/BB cooling fan interchangeability?
Reply #1 on:
November 21, 2007 - 11:51:52 AM »
the clutch is the same bolt pattern , there were a # of different fan sizes you probably need a 17 or 18 " the C bodys were larger at 19-20 " , Flexalite has a 6 blade fan 18" that will bolt on
Logged
miketyler
Resident
Reply #2 on:
November 21, 2007 - 02:01:04 PM »
There really isnt much wrong with my current setup - I was only considering this if there is a benefit of more flow via a larger diameter or higher pitched fan or gas savings from running a clutch. Is the flexalite fan higher pitched or a better solution than stock?
Logged
72' Cuda restomod
70 Mustang Mach 1
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
November 21, 2007 - 05:54:58 PM »
it is similar to stock , the cluch will save you $$ & power though as it will free wheel when it is not hot enough to need it
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
