Author Topic: rear axle size  (Read 2026 times)
Offline GreenFish
rear axle size
« on: January 27, 2004 - 07:58:54 AM »
Are the rear axle lengths for an E-body, the same as a B-body?,
in other words, can i swap a dana rear from my buddies coronet into my cuda without cutting ?
lemonboy69
Re:rear axle size
« Reply #1 on: January 27, 2004 - 10:09:28 AM »
Ummmm... couldn't tell ya... I could tell ya for an A-body... lol... but that doesn't help now does it... ::) :P
LB
Re:rear axle size
« Reply #2 on: January 27, 2004 - 02:55:51 PM »
This is definitely a "Chryco" question. I'm almost sure the B-body axle will be a little longer. You can use it, but the wheels will stick out a little.
Offline BIG MIKE
Re:rear axle size
« Reply #3 on: January 27, 2004 - 03:32:13 PM »
i'm just stop in....look in the archives...i've posted all the lengths.  here is a link..
http://www.cuda-challenger.com/yabbse/index.php?board=22;action=display;threadid=1477
Re:rear axle size
« Reply #4 on: January 27, 2004 - 05:39:13 PM »
the E body diff is actually Wider then the B body  you can get new seats welded onto the housing & do the swaop though , you will need to get the pinion angl ecorrect to do this though
Offline 360 'CUDA
Re:rear axle size
« Reply #5 on: January 27, 2004 - 08:38:59 PM »
Just go down the the mopar performance store at your
local dealership and buy or order the Super Stock
spring hanger kit. No cutting or welding and it bolts
that B-dana right in.
Gives you extra wheelwell room too.
If ya got a little money left over use the 2inch longer
spring hanger kit and bolt in some new Super Stock
springs 8) 8)
They hook like a dog and rattle teeth fillings too
Offline BIG MIKE
Re:rear axle size
« Reply #6 on: January 27, 2004 - 09:08:36 PM »
if my earlier post came off kind of bad i'm sorry...just some stuff around here kind of put me on edge...
Re:rear axle size
« Reply #7 on: January 28, 2004 - 03:04:03 AM »
springs 8) 8)
 Not quite correct there are 3 different widths for B Body diffs  8)
Offline GreenFish
Re:rear axle size
« Reply #8 on: January 28, 2004 - 06:35:00 AM »
ok this one is off of a 69 coronet. and its a dana rear.
Thanks for all your info folks, ive been meaning to put SS springs on the car soon any how.
Offline 360 'CUDA
Re:rear axle size
« Reply #9 on: January 28, 2004 - 11:31:42 PM »
8 3/4 rears are the workhorse of our hobby but..........
having the D-bomb under the car gives a chebbie second
thoughts about his ten bolt :-\
Offline BIG MIKE
Re:rear axle size
« Reply #10 on: January 28, 2004 - 11:36:51 PM »
depends on what he has plans for the car..
Offline 360 'CUDA
Re:rear axle size
« Reply #11 on: January 28, 2004 - 11:47:48 PM »
I think the SS springs comment gives him away ;D
Offline GreenFish
Re:rear axle size
« Reply #12 on: January 29, 2004 - 06:35:40 AM »
yeah, you got me...lol..  i am planing on maybe doing some bracket racing this summer. (and eating some fords and chebbys on the street too)
I am considering a new tranny with a trans brake and all, i just have to figure out if i can use a trans brake and keep my slap stick shifter, (want to keep it stock looking)
Offline 360 'CUDA
Re:rear axle size
« Reply #13 on: January 31, 2004 - 12:52:41 AM »
The slap stick would be cool but it won't work with a
reverse pattern valve body without modifications
Also the brake would shock the tires on the street and
just spin em.
We tried a brake on the track without changing anything
else and it was good for 3 tenths but hard on gears and
sprags. in that order..
1:50 60 foot times and tons of air under the front tires
but not as consistant on the little slicks we had to run.
