Author Topic: Follow up to Intermittant Charging  (Read 1337 times)
Offline 422STROKER
  • Member Since 6/3/06
« on: November 22, 2007 - 02:52:51 PM »
http://www.cuda-challenger.com/cc/index.php?topic=39384.0
As a follow up to my question, I swapped the VR and cleaned the ground up a bit on the firewall, one of the bolts wouldn't really tighten up so I may weld that one shut this winter and redrill.  But, I swapped the new VR in and it was charging fine.  I'll have to keep an eye on it.
I also picked up a new Alternator for the motor swap this winter either way...  I'll put that in when the time comes.  Came with a printout for 65A.  I'll need to add a bypass at that time since the Aftermarket Stereo and Amp will add to the existing loads.
Thanks to all those who helped!
Tom :bigsmile:
Tom
Offline GoodysGotaCuda
Re: Follow up to Intermittant Charging
« Reply #1 on: November 23, 2007 - 04:39:47 AM »
sounds good, hope all goes well with it!
-Mike
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline JayBee
« Reply #2 on: November 23, 2007 - 06:52:03 PM »
Thanks for the update, the previous thread may just help someone else out. You know, keeping a known good one in the glove box ain't a bad idea.
John
1970 Barracuda convertible
2014 Toyota Avalon
