71 Challenger Project
Author Topic: 71 Challenger Project  (Read 33357 times)
Offline troutstreamnm
Re: 71 Challenger Project
« Reply #120 on: February 16, 2008 - 11:18:52 PM »
Stripes are on!
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline hemiken
« Reply #121 on: February 17, 2008 - 06:27:54 AM »
 :wow: Haven't they changed the look of the car, looks way cool man...............
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #122 on: February 17, 2008 - 06:28:11 AM »
Too bad about your sound deadening kit but maybe its better than what the factory did... :eek4:
the rest of the car is looking sweet and your right only the people that see the pictures will know about the matt.... :poopoke:
Cheers.. :cheers:
Go Fast & Have Fun...
Offline wally426ci
    • maryland mopars
« Reply #123 on: February 17, 2008 - 08:40:39 AM »
Looks awesome!! can you tell us what sound deadening kit you bought so we dont buy the same? i was thinking of getting one for mine.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #124 on: February 17, 2008 - 10:04:29 AM »
wally, the kit was from an eBay vendor named "Replacements" from Hatfield, AR.  The part is titled: 1970-74 Challenger Sound Deadener Kit (4-pieces), Item # 260174786994.  I have no issues with the vendor, but this particular item is a POS.  I'd show you more pics, but no need to dwell on this issue  :horse:
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline Challenger_7
« Reply #125 on: February 18, 2008 - 09:59:42 AM »
Great progress there buddy, and sorry about your disappointment.
One clarification about your A/C heater box, as I am doing mine now. Mine is seriously cracked in some places so I am having it fiberglassed where needed.
However, my two halves are held together with clips, where as yours with screws. Are there different models or what?
Thanks, Farouk
71 Chally Conv 383 Magnum Manual - Hurst
71 Chally Auto 383 Magnum R/T 100% Orig
71 Chally Auto 400
70 Chally Auto small block
72 Charger SE Manual - Hurst
73 Plymouth Satellite "Sebring Plus" 100% Orig
Others: http://www.cardomain.com/id/Challenger_7
« Reply #126 on: February 18, 2008 - 08:34:42 PM »
Sorry Farouk, I don't know the answer to your question other then if they are both original there must have been some production line changes :(
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
« Reply #127 on: February 22, 2008 - 07:02:34 PM »
Got my engine back from the builder  :bananasmi  It's a warmed-over 383 that runs really strong and is a great street workhorse.  I don't care what anyone says, but a build up 383 is a great motor!  Hopefully will be even better after the rebuild.  Here's some details:
-Forged TRW pistons, 0.040 over, 10:1 compression w/closed chamber head
-Factory heads (516 castings) with the valves opened to 2.08 intake and 1.74 exhaust (simulates the 915 heads)
-Factory rockers and the shafts are the Direct Connection hardened and polished
-Mopar Purple Shaft cam .484 (284)
-Crankshaft was turned .010 under on rods and mains then polished and balanced
-Rod and Main bearings are 0.10 oversized Clevite 77
-Double roller timing chain with steel gears
-ARP head and rod bolts
-high volume oil and water pump
-Factory steel crank
-Facory style windage tray
-Mopar Performance aluminium dual-plane intake
-Ceramic coated headers
-Edelbrock 750 cfm carb
I painted the motor with the POR-15 engine enamal before I decided to do a full rebuild and this is what the block looks like AFTER the hot tank.  All it did was take the shine off it!  :roflsmiley:  They bead-blasted the heads to clean them up.  Now I need to finish putting it back together and do another coat of POR-15.  Another piece of the puzzle is back!
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline wally426ci
    • maryland mopars
« Reply #128 on: February 23, 2008 - 11:14:05 AM »
at least the paint is clean!  :roflsmiley: man i cant wait to see this car driving!!!!!!!! im almost as excited as if it were mine, it just looks so good!  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline RusTy/SE
  • Just havin' fun
« Reply #129 on: February 23, 2008 - 01:48:36 PM »
Nice and clean :thumbsup:   POR-15 :ylsuper:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
« Reply #130 on: February 29, 2008 - 09:54:58 PM »
Finished repainting the engine today so that chore is done  :jumping:  Got the dash frame in and started wiring.  The M&H wiring kit is an exact match to the factory wiring so it has been fairly easy so far.  I've got a couple orphan wires that I need to figure out.  :clueless: Guess it's time to put on the dash pad and a/c vents next.  It's coming together  :cooldancing:
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline hemiken
« Reply #131 on: February 29, 2008 - 11:50:19 PM »
 :clapping: Looking good my man,  what paint did you use on your engine buddy.
« Reply #132 on: March 01, 2008 - 09:01:27 AM »
Thanks Hemiken.  I repainted using POR-15 Hemi Orange.  It's guaranteed not to burn off so unless the hot tank incident hurt the basecoat chemically, it should be bulletproof and look great for a long time.  My oil pan was powdered coated using Eastwood's Hemi Orange paint.  You can see that all Hemi Orange is not created equal!  :o  Not a show-stopper issue to me and will be a subtle variation once in the car  :misbehaving:
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Offline hemiken
« Reply #133 on: March 01, 2008 - 05:29:23 PM »
 :faint: Your engine crane looks closer to the color of the engine than the oil pan, it is amazing how different Hemi Orange is between different brand paints. :clueless:
Still looks sh!t hot though, keep up the great work old mate. :woohoo:
« Reply #134 on: March 02, 2008 - 12:47:32 PM »
Here's a mock-up of the top of my 383 with the Weiland intake and 750 CFM Edelbrock.  I was going to paint the intake Hemi Orange like the rest of the motor, but kinda like the natural aluminum look.  What do you think?
Question, do you RTV the surface between the heads and the paper gasket attached to the valley pan?  Likewise the surface between the aluminum intake and the paper gasket on top of the vally pan?  Seem like someone told me once those surfaces should not be RTV'ed.  Thanks.
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
