Author Topic: Need a little help for my DeSoto..  (Read 788 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: November 22, 2007 - 06:01:12 PM »
I know this 59 DeSoto aint no e-body, but this is the only forum where somebody do something to help out...  :ylsuper:
The heater system, air up/down controled by vacuum, got no hoses at all, anyone know where to get info on how to connect new ones..???
The temp, is somehow controled by this,  - how, and where to get a new one..???
Aint something missing on the radiater core..???
Re: Need a little help for my DeSoto..
« Reply #1 on: November 22, 2007 - 06:24:06 PM »
In the top picture I see no vacuum fittings, appears to be cable operated with an electrical switch that has no wires connected...
A good resource might be the Chrysler Imperial Club
http://www.imperialclub.com/
« Reply #2 on: November 23, 2007 - 07:21:03 PM »
The top pic may have had a vacuum switch connected to the rear of the switch shown , it looks like a port through the firewall for the vacuum lines as well , you need to connect a vacuum line to the manifold to supply vacuum , it would then go through the switch & out to the valve on the rad to open the flow
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: November 24, 2007 - 04:49:19 AM »
I got a vacuum hose from the manifold, going into the car, ending with a screw in it for block up..
What I need is hoses from controlpanel to air up/down vacuum valves...
The "thing" on the pic., is cable-controled, from the temp. control, you pick a temp, and it got a feeler in the airchanel, then, - somehow the electric connections on it somehow is supposed to regulate the valve on the core... I think.. :clueless: :clueless: :clueless:
