Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Finding Number 1 On Distributor?
« previous
next »
Print
Pages: [
1
Author
Topic: Finding Number 1 On Distributor? (Read 1666 times)
bordin34
Full Member
on:
November 23, 2007 - 11:53:41 AM »
How do I find out where my number 1 wire goes on my distributor. The engine is a 73 400. I changed the distributor cap and forgot where it goes there are no markings as to where it goes on the new cap or the old.
Logged
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Moparal
Permanent Resident
Re: Finding Number 1 On Distributor?
Reply #1 on:
November 23, 2007 - 11:56:40 AM »
Pull your number one plug and bump the engine over with your finger covering the hole. When it pushes your finger off, this will show you where #1 is for the location, then look at your balancer timing marks, you cand move the crank back a little to get it even closer if you went too far
Logged
nivvy
Guest
Reply #2 on:
November 23, 2007 - 12:23:24 PM »
this what you are looking for...this is what you are looking at from the passenger fender looking straight at the distributor.......
Logged
bordin34
Full Member
Reply #3 on:
November 23, 2007 - 12:38:49 PM »
Are you sure? Mine was set up with 4 where the 7 is so I guess it was 180 off and it ran. I was told in a reply on another forum that 1 was directly to the left of the hold down clip on the front which made sense to me since I know about where 4 was.
Logged
cowboy
Sr. Member
Denmark
Reply #4 on:
November 23, 2007 - 01:20:05 PM »
If the distributor has been of the engine, at anytime, # 1 could be anywhere...
Do like Moparal told you...
Logged
MoPar's for Cruizin, Racing & Pro-touring:
www.CowboyCars.dk
1930 Plymouth Hot Rod wannabe - 1957 DeSoto Fireflite Sportsman - 1967 RaceCuda - 1968 Barracuda - 1971 Challenger R/T Conv.
nivvy
Guest
Reply #5 on:
November 23, 2007 - 01:54:04 PM »
The pic I posted was where the plug wires plug into the cap...........
Logged
bordin34
Full Member
Reply #6 on:
November 23, 2007 - 02:04:53 PM »
I did the finger over the plug hole thing and my wires plug in 180* off from what you posted.
Logged
matt63
Sr. Member
Reply #7 on:
November 23, 2007 - 02:06:53 PM »
When installing a distributor you can put #1 anywhere you like by changing the position of the distributor drive gear. Thus, we can't tell you how this was done by whoever built your engine. There is a "std" position which I believe requires the horizontal slot in the distributor drive gear to be perpendicular to the engine centerline when the engine is at TDC on cylinder #1. If you don't want to change the distributor drive gear orientation, just follow Moparal's instructions. The rotor will be pointing to the #1 wire. Hope this helps.
ps If you are out 180 degrees pull the distributor up and rotate the distributor shaft 180 and reinstall.
Logged
Matt in Edmonton
'68 Valiant
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
