Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
#1 On Mopar Distributor Cap?
« previous
next »
Print
Pages: [
1
Author
Topic: #1 On Mopar Distributor Cap? (Read 1624 times)
FRSHFSH
Jr. Member
on:
November 23, 2007 - 07:00:19 PM »
I need a little help; I am installing a Mopar electronic ignition conversion kit. I took the spark plug wires off exactly from the old distributor cap, but its not starting. The #1 cylinder was maked on the old distributor cap but not on the new one, can anyone tell me how to identify the #1 cylinder/plug wire on the distributor cap?
Thanks for the help!!!!
Logged
"We will remodel the house once the cuda is finished"
nivvy
Guest
Re: #1 On Mopar Distributor Cap?
Reply #1 on:
November 23, 2007 - 07:05:54 PM »
this what you want....this view is from the passengers side of the car looking right at the distributor!
Logged
ted
Sr. Member
74 cuda, 70 challenger r/t
Reply #2 on:
November 23, 2007 - 07:34:34 PM »
works assuming distributor is installed the way the factory did it.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
November 23, 2007 - 07:36:40 PM »
the Best way to do this is to remove #1 spark plug , put your finger over the hole & bump the engine over until the air pressure forces your finger out , you are now on #1 compression stroke & the rotor will be pointed close to where #1 should go
Logged
bordin34
Full Member
Reply #4 on:
November 24, 2007 - 12:07:00 AM »
I did that and it was 180* off from the picture that StRoKr posted. I started it and it runs so I guess its right. New cap didn't solve my problem so a compression test, then off with it's heads.
Logged
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
FRSHFSH
Jr. Member
Reply #5 on:
November 28, 2007 - 02:56:38 PM »
Found it, thanks for the help guys!!!!!
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
November 28, 2007 - 11:10:21 PM »
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
