Hi all! I finally got my Challenger running and am in the process of breaking it in and tuning it and I have a few problems. I am new to carburetors, and have no experience until now with tuning them (and I suck at it.) I am running an Edelbrock 800cfm Thunder AVS unit, and can't seem to get it dialed in. I know, Holleys are better but I didn't know that when I bought it years ago and being a soon to be college grad in 3 weeks I cant afford another one for quite some time so I am kinda stuck for now.
At idle (950 RPM) only it seems like it runs a lot rougher than it should. I have tried setting the idle mixture screws, and it has helped a little but not too much. I have checked for vacuum leaks and adjusted the timing to where it seems happiest but it still shakes quite a bit, especially in gear. Another issue I have is when the fast idle is set it seems to slowly increase in RPM up to 2300 from 1500 after a few minutes of run time. I have adjusted the choke but it didn't do anything. Also, while tuning the off idle circuits I can't seem to get this carb to run rich. Every time I jet it up I have pulled the plugs and they still look too lean. The ground strap is light gray and the porcelain is chalk white. I am about to jet it as rich as possible according to the fuel map that came in the instructions but I seriously doubt it will be enough. The car just doesn't pull like it should, but I haven't really taken it over 4500 RPM yet either. My engine combo is a 408 stroker small block with Edelbrock Performer RPM heads and cam, Air Gap intake, Dynomax ceramic headers and 2.5" dual exhaust with H-pipe, and an MSD Pro Billet Ready to Run distributor with a Blaster 3 coil. I have the timing set to 17* initial and 38* total all in by 2400 RPM. I am running vacuum advance too. Plug gap is set to .045". Behind it is a built 904 and an 8 3/4 with 3.91 gears and a Powertrax locker. Any help will be mucho appreciated! - Dan
