Author Topic: Update on the R/T SE  (Read 9709 times)
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« on: January 28, 2004 - 11:10:55 AM »
When we last left off with our story...we had just taken off the front suspension (to clean up), and lowered the engine onto the k-frame.
We've been working every night, but had a few delays.. (compressor died, etc.).  Here's what we've done.
Cleaned and painted all the front suspension pieces.
Cleaned, sanded and repainted the entire bottom of the car.
Removed, cleaned and repainted the rear-end.
Repainted the trunk.
  --  from here, I think we're actually moving forward instead of cleaning up from 2 years outside.
Installed the front to rear brake and fuel lines (thanks for the tip on doing that first...great help!)
Installed the rear-end.
Installed the gas tank with pad.
Hear are some pics...
[attachment deleted by admin]
Offline Rev-It-Up
  • Global Moderator
Re:Update on the R/T SE
« Reply #1 on: January 28, 2004 - 11:11:26 AM »
Fuel lines...we still need a few clips.
Offline Rev-It-Up
  • Global Moderator
« Reply #2 on: January 28, 2004 - 11:11:58 AM »
Rear-end being installed...
Offline Rev-It-Up
  • Global Moderator
« Reply #3 on: January 28, 2004 - 11:12:27 AM »
Rear-end installed...
Offline Rev-It-Up
  • Global Moderator
« Reply #4 on: January 28, 2004 - 11:12:58 AM »
Rear-end and gas tank,  ta da!!!
« Last Edit: January 28, 2004 - 11:14:39 AM by Rev-It-Up »
lemonboy69
« Reply #5 on: January 28, 2004 - 11:47:28 AM »
LOOKS AWESOME!!!! ;D Question... how'd you get the car high enough to put 3 cement blocks under her??? That's almost 3 feet off the ground.... :o ???
LB
Offline Tim440RT
  • Get an R/T
« Reply #6 on: January 28, 2004 - 12:12:54 PM »
 :o :o :o :o.. that is looking REAL nice, i wish i had the time and money to do a complete resto :-[.....keep up the good work, and most of all, keep up the updates  ;D
1970 Challenger R/T 440
« Reply #7 on: January 28, 2004 - 01:22:58 PM »
looks great !
 Be Careful around those Cinder blocks they are about the Worst thing to use , & can crush at any time not that you have much weight on them yet
« Last Edit: January 28, 2004 - 01:24:34 PM by Chryco Psycho »
Offline Rev-It-Up
  • Global Moderator
« Reply #8 on: January 28, 2004 - 01:41:41 PM »
LB, in answer to your question....vewwy, vewwy cawfuwy.  Actually we used our engine hoist and our floor jack with some downhome southern ingenuity.  It made sanding under there tolerable.
Tim...thanks for the kind words of encouragement!!
Chryco, thanks for the heads-up.  Hopefully the car won't be up there very long.  Hubby figured that each set of blocks could hold up to 2000 lbs.  But, now, we may put in a back-up plan since we will be under there a lot in the near future.  Better safe than very, very sorry!
Offline 4Cruizn
  • HEMI FISH
« Reply #9 on: January 28, 2004 - 02:02:13 PM »
Rev that ROCKS!! Everything looks awesome!!  You're making me want to work in the garage!!  8)
Offline Rev-It-Up
  • Global Moderator
« Reply #10 on: January 28, 2004 - 02:31:50 PM »
Come over any time...we could use the help... ;D  j/k
Offline Moparmatt
  • Mopar or No Car - Member Since 10/09/03
« Reply #11 on: January 28, 2004 - 02:40:28 PM »
Looks very nice... inspires me to go and work on my Mopar... no, wait... I don't have one yet. :'(
Any luck with the Gator Grain vinyl top so far?
lemonboy69
« Reply #12 on: January 28, 2004 - 03:00:50 PM »
I'm inspired to go work on mine... but I don't have any freaking time!!!! >:( >:( New job hunt, school, current job.... ::) someone just shoot me!!
LB
Offline Carlwalski
« Reply #13 on: January 28, 2004 - 05:25:49 PM »
Looks bloody boomers REV!!!  :D ;)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #14 on: January 28, 2004 - 05:27:00 PM »
I will drop by & help ... It has to be warmer there  ::)
