Author Topic: Update on the R/T SE  (Read 9717 times)
Offline 1973challenger360
Re:Update on the R/T SE
« Reply #30 on: January 30, 2004 - 02:30:58 AM »
my mother lives in Helena, MT it was -40 there last week without the wind chill, I thought it was cold here at 44deg, thats 84deg warmer than there.
wheels I know that Rain lived in Auburn area for 19.5 years and 1.5 in Montana, now in sunny phoenix  ;D and im never going back....
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #31 on: January 30, 2004 - 09:28:27 AM »
rtgambit, thanks!  Now we're waiting for our torque converter and drive shaft to come in.  We're also waiting for our front and rear disc brakes to come in.  Hopefully they will all be here next week.  In the meantime, we'll start putting the front suspension back together...probably start that tonight.
Offline Tim440RT
  • Get an R/T
« Reply #32 on: January 30, 2004 - 09:31:55 AM »
Rev, what Kind of torque converter did you guys end up going with? I remember you were debating with what you were going to get.
1970 Challenger R/T 440
Offline Rev-It-Up
  • Global Moderator
« Reply #33 on: January 30, 2004 - 09:51:29 AM »
We decided to go with a Phoenix converter.  They're based in Texas and they have done some great stuff for my brother.
http://www.phoenixtrans.com/html/converters.html
lemonboy69
« Reply #34 on: January 30, 2004 - 03:51:25 PM »
How big of a stall though?? I forgot what size cam you have in that engine too... ::) ???
LB
Offline Rev-It-Up
  • Global Moderator
« Reply #35 on: January 30, 2004 - 04:15:44 PM »
Our cam is a Comp Cams...mild cam, duration is 224, lift .470.  The stall speed for the converter is 2200 - 2400.  Just found out it will be here next Wednesday...we'll install it on Thursday!!
lemonboy69
« Reply #36 on: January 30, 2004 - 04:25:49 PM »
Sounds like it should be a good setup... should hook nicely off the line!! ;) When I talked with ISKY for my cam.. the one I'll probably be getting is .448 lift with 228 duration at .050" (264 advertised)... need to run a 2500 stall with that.... :D
LB
Offline RusTy/SE
  • Just havin' fun
« Reply #37 on: January 30, 2004 - 05:59:46 PM »
Great progress Rev. Maybe one weekend i could rent a car and see it firsthand. Pleeeeeeezzzz  ::) ::)
Russ
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline Rev-It-Up
  • Global Moderator
« Reply #38 on: January 30, 2004 - 06:12:07 PM »
Hey Russ, that sounds like fun.  Maybe we can time it right and you can be here when we fire her up for the first time... ;D
Offline Carlwalski
« Reply #39 on: January 30, 2004 - 06:18:35 PM »
How REV speaking of stall, have you chosen a brand or called them up to ask what stall for your set-up?  ??? ;D
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Rev-It-Up
  • Global Moderator
« Reply #40 on: January 30, 2004 - 06:24:41 PM »
We've talked with them (Phoenix) and gave them all the specs for our car...engine, cam, trans, rear-end, etc...and told them what we were doing with the car (cruising).  We decided the best set-up for us would be the 2200 - 2400 stall.
Offline Carlwalski
« Reply #41 on: January 30, 2004 - 06:30:29 PM »
Sounds about right I was with Mike thinking 2500rpm but they would know and there sin't too much difference. So will you be getting one?  :D
Offline Rev-It-Up
  • Global Moderator
« Reply #42 on: January 30, 2004 - 06:38:24 PM »
Yep, it arrives next Wednesday!!   ;D
Offline Carlwalski
« Reply #43 on: January 30, 2004 - 06:45:08 PM »
Yehaaaaaaaa good stuff REV!  :D ;)
lemonboy69
« Reply #44 on: January 30, 2004 - 07:42:19 PM »
NZ... I was talking about the stall I need to run for my 'Cuda with the cam I'll be getting... just so similar to Rev's!!.. :D
LB
