Author Topic: Spring Relo kit  (Read 1493 times)
nivvy
Spring Relo kit
« on: January 28, 2004 - 11:52:25 AM »
Anyone ever install one?  Do's and dont's?
Just wanna stuff the biggest tires in there...lol
With a relo kit what is the maximum rim/tire come I can use...and the proper backspacing.......thx to all....
Jason
Re:Spring Relo kit
« Reply #1 on: January 28, 2004 - 01:21:26 PM »
ti would depend on wether you are using the offset mounts which work well & are easy to install or cuttin gthe front mount into the frame rail which is a lot harder to do . both kits are available from Mopar.
nivvy
Re:Spring Relo kit
« Reply #2 on: January 29, 2004 - 02:16:23 PM »
I would use offset mounts...........what would be the perfect backspacing? for 15*10 rim to stuff the wheelwells?
thx
Jason
Offline 360 'CUDA
Re:Spring Relo kit
« Reply #3 on: February 01, 2004 - 11:39:38 PM »
just in case
the recipe that should fit everyones E-bodies
1962 to 1970 B-body (2 or 4 door) 8 3/4 rearend
That is a rearend that has a springseat of 44 inches
center to center and an overall length of 59.2 inches
from brake drum to brake drum
Dana 60's work well too
buy the 2 inch longer offset  spring hanger from Mopar
A-body Super Stock springs or equivalent
10 inch wide wheels with an offset of 5 1/2 inside and
4 1/2 outside
295 / 50s size tires on 15 inch wheels
275 / 60s look interesting too but the drivers side fender lip might need a quarter inch or so trim as
the outside of the tire is closer on that side .
You wouldn't want to shave off your white letters
 8) 8) 8) 8) 8) 8)
Offline Grancoupe
Re:Spring Relo kit
« Reply #4 on: February 12, 2004 - 04:07:53 PM »
I agree with 360cuda about the fit for 275 60 tires. I have a set on my cuda and had to trim the quarters bach a bit.
