Author Topic: What is this bolt / plug for..???  (Read 1572 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: November 26, 2007 - 05:57:55 PM »
What is this bolt / plug, rigth beside the antifreezeplug, got one on each side..???
Offline quagmire
  • Traction Impaired......
Re: What is this bolt / plug for..???
« Reply #1 on: November 26, 2007 - 06:03:58 PM »
Those are the engine block drains for the water jackets.
Offline 426HEMI
« Reply #2 on: November 26, 2007 - 06:06:01 PM »
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: November 26, 2007 - 06:14:47 PM »
No comprende,- sorry..???
Offline 71GTX
  • It's a fine line between a hobby & mental illness!
« Reply #4 on: November 26, 2007 - 06:15:23 PM »
You can drain your engine of water thru this type of plug....
69 RoadRunner (clone)
70 Cuda 383 4 speed (project) one of the first few off the line at Hamtramck with a 1017XX VIN
70 Cuda convertible 340 4 speed (project)
70 Barracuda (project)
71 GTX 440 4 speed (project)
72 Cuda 340 3 speed (project)
3 Harleys
95 Dodge Ram 2500 Diesel 4x4
Expensive Pee is the end result of Expensive Beer!
Offline cudabob496
« Reply #5 on: November 26, 2007 - 07:16:55 PM »
When they've been in there for a while, and you unscrew them, water may not initially drain out because corrosion products have built up in the bottom of the engine coolant passages.  If you dig in there a little with a small screw driver, the rust will break up and the water come pooring out.
2011 Kawasaki Z1000
Offline 426HEMI
« Reply #6 on: November 26, 2007 - 07:23:58 PM »
That is why when you rebuild an engine you need to take all of the plugs out of the engine.  There might of even been all of this in the engine when it came from the factory.  Sand and rust will be in there.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #7 on: November 27, 2007 - 02:41:12 AM »
OK, - thanx..
But I got all the antifreezeplugs out of it, and try to get a little space in there for water...???
It.s my 1959 383cui, and it's all filled up with "stuff"....  :pullinghair: :bricks1:
Offline 71GTX
« Reply #8 on: November 27, 2007 - 11:40:14 AM »
Was a 383 made that early?? I believe that 361's were made around that time....
3 Harleys
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #9 on: November 27, 2007 - 03:14:47 PM »
In 59, you could get the 383cui. as a B-Block, (Dodge-DeSoto) - and as a RB-block (Chrysler-Imperial)..   :ylsuper:
Offline 71GTX
« Reply #10 on: November 27, 2007 - 03:35:34 PM »
Learn something new everyday! Thanx!  :wow:
3 Harleys
