Author Topic: High Volume Mechanical Fuel Pumps  (Read 875 times)
Offline Cudaah
« on: November 28, 2007 - 10:10:23 AM »
I am looking for a quality HI-PO unit and noticed a few things.  I currently have a 3/8" line and think a 1/4"  fuel pump will restrict fuel flow.
Carter Pumps are only 1/4"  inlet/outlet
Holly strip/street has a choice of 3/8 or 1/4"
Edelbrock is 3/8"  inlet/oulet
Any comments?
Re: High Volume Mechanical Fuel Pumps
« Reply #1 on: November 28, 2007 - 10:39:24 AM »
I have had problems with the Holley pumps , I use the Carter usually but I drill the openiings behind the fittings out to 5/16 or a bit larger , at least to match the hole inside the fittings , they seem to flow enough for the engines I have built , be careful though Carter misboxes the Big block Dodge pump with another pump often , if the pump touches the block or doesn`t have 8 bolts holding it together you have the wrong pump , return it
Offline Kapteenikosmos
« Reply #2 on: November 28, 2007 - 10:50:34 AM »
 :scared: I just ordered some stuff from Rockauto and that order also included carter mechanical fuel pump for BB. Mine was clamped (or whatever is the right term) together so no bolts. That means that the pump is wrong? Returning stuff from Finland isn't very cheapo.
I left the pump to my workplace and I can take a pic from it tomorrow if CP can say from the pic if it is right or wrong? I cannot test fit into the block because I'm 150 miles from my car for next two weeks.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
« Reply #3 on: November 28, 2007 - 11:30:44 AM »
This is the hi-volume Carter pump I am useing. 3/8" fitting on both ends. This is for a big-block.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRT%2DM6903&N=700+4294891547+4294908110+400415+4294840062+115&autoview=sku
« Last Edit: November 28, 2007 - 05:00:10 PM by MEK-Dangerfield »
« Reply #4 on: November 28, 2007 - 11:09:15 PM »
the Summit pic is the big block Mopar pump mike
the crimped pump will work but it is just a standard volume not high volume pump Cowboy
Offline dodge freak 2
« Reply #5 on: November 29, 2007 - 05:35:36 AM »
Summit pictures are wrong 50% of the time. Even what they say about the item can be too. Its a great place to shop, as long as you know what you need.
What they show you and tell you about the item and what it really is can be 2 diff. things, guess they sell too much stuff to have everything perfect.
kudakidd
« Reply #6 on: December 07, 2007 - 12:06:35 PM »
I've always used Carters. You put in the in/out nipples with the I.D of your choice
