Author Topic: 74 Cuda Seatbelt interlock  (Read 2529 times)
Offline CUDA JAS
  • vroooooom!
« on: December 04, 2007 - 08:08:15 AM »
Is it possible to remove the seatbelt interlock entirely?
I have to rebuild my engine wiring harness, so I figure if I am going to change anything, now is the time?
So can it be done?
74 'cuda 360/727
Just call me a gearhead!
Offline 73EStroker
Re: 74 Cuda Seatbelt interlock
« Reply #1 on: December 04, 2007 - 04:20:01 PM »
Yes it is possible. You should remove the excess wiring and you may have to block off the dash area where the "fasten seat belts" light was placed. I did this to my 73 Chally which has the light in the right side of the dash.
Barry (Salmon Arm)
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #2 on: December 04, 2007 - 05:01:50 PM »
you will need a wire from the "g" terminal on the starter replay to the neutral safety switch.
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: December 05, 2007 - 08:27:43 AM »
cool thanks.  I will give it a try.
Where should the wire from the started realy attach to the neutral saftey switch?
Good point about the seat belt light...I think I will just leav it there..iot has never worked anyway!
74 'cuda 360/727
Offline ted
« Reply #4 on: December 05, 2007 - 11:13:04 AM »
I BELIEVE its the middle terminal.
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: December 20, 2007 - 07:59:17 AM »
Man, I am not sure about this... I found what I think is the seatbelt interlock controller under the dash, and there are a lot of wires going into and coming out of it.
It seems like it might be complicated to remove all the wires.  I just don't want to screw anything up.
Any advise, or I am worried over nothing?
74 'cuda 360/727
Offline ted
« Reply #6 on: December 20, 2007 - 02:26:10 PM »
just unplug the wire that is now on the neutral safety switch  and run a new wire.
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: December 20, 2007 - 08:11:23 PM »
It is not so much that one wire, it is all the other wires that I am worried about.  I woudl liek to remove all parts of the interlock system.
It has never worked on my car anyway.
jas
74 'cuda 360/727
Offline ted
« Reply #8 on: December 21, 2007 - 04:04:21 PM »
i just left the other wires  intact.
Offline rusty dodge
  • 74 challenger 440-727-3:55
« Reply #9 on: December 21, 2007 - 07:10:31 PM »
When I put my interior back together, I left out the controller from under the dash and wiring that ran under the carpet to the the seat belts. I wasn't conserned about the "seat belt" lamp working. The original wire harness & plug to the controller is still under the dash not used. Looked like a PITA to remove all that wiring - just leave it.
« Last Edit: December 21, 2007 - 07:16:47 PM by rusty dodge »
