1970 RT/SE Challenger 4 speed, clone or real 4 speed RT/SE...
Author Topic: 1970 RT/SE Challenger 4 speed, clone or real 4 speed RT/SE...  (Read 7913 times)
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
Re: 1970 RT/SE Challenger 4 speed, clone or real 4 speed RT/SE...
« Reply #15 on: April 06, 2008 - 02:02:45 PM »
Coulden get a good picture under the hump, but i will try again.  :cheers:
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
« Reply #16 on: April 06, 2008 - 02:24:01 PM »
from those pix I would say factory , the edge is clean cut, where the floors are cut to accomadate the hup & the seal inside the car looks sloppy like factory
Offline ESGEE
    • SG´s site
« Reply #17 on: April 06, 2008 - 02:31:18 PM »
When i look at it i get the feeling that it is stock, but since i dont have fenderplate or broadcast sheet i will never know for sure...
70 Charger 500
Offline ESGEE
    • SG´s site
« Reply #18 on: June 20, 2008 - 12:37:22 PM »
Bump :bigsmile: Havent got any any info on this car so the search goes on... :cheers:
70 Charger 500
Offline FY1 RT SE
« Reply #19 on: June 20, 2008 - 03:12:44 PM »
What number is stamped into the 4 speed?
Tower Rat 95B
« Reply #20 on: June 21, 2008 - 06:51:34 AM »
 Exactly,  what # is stamped in to the 4 speed???????
 Looks like a factory 4 speed tunnel to me , also appears to be a non console cause there are no console mounts, they would be weld right to the tunnel if it had a console.......
 btw my JS23VOB is non console 4 speed , I sure like the look of an E- body 4 speed with out the console :ylsuper:.........
Offline ESGEE
    • SG´s site
« Reply #21 on: June 22, 2008 - 04:10:09 PM »
It does look fully stock to me to, but without fendertag and broadcastsheet i can never be sure.
I´ll check the numbers when i get the tranny back from checkup :cheers:
70 Charger 500
Offline ESGEE
    • SG´s site
« Reply #22 on: July 27, 2008 - 06:56:11 AM »
Here is the numbers on the tranny :bigsmile:
70 Charger 500
« Reply #23 on: July 27, 2008 - 07:59:07 AM »
Does not lok like the vin on the stamped trans pad is the same as the vin on the dash
sleepychallenger
« Reply #24 on: July 27, 2008 - 08:06:59 AM »
Alan, you must have your mopar super glasses, i cant see that vin at all.  :bigsmile:
« Reply #25 on: July 27, 2008 - 08:12:25 AM »
I can def see a 3 and other non matching numbers
sleepychallenger
« Reply #26 on: July 27, 2008 - 08:14:54 AM »
 guess i need some :bigshades: to see it
« Reply #27 on: July 27, 2008 - 08:15:55 AM »
Or a good video car with a good pixel monitor :2thumbs:
« Reply #28 on: July 27, 2008 - 08:16:54 AM »
All ESGEE has to do is scrape the paint off of the pad and everyone will see it then. The numbers are there
sleepychallenger
« Reply #29 on: July 27, 2008 - 08:18:48 AM »
im stuck with what they give me  :misbehaving:
