Author Topic: Spring Relo kiit  (Read 802 times)
nivvy
Spring Relo kiit
« on: January 29, 2004 - 10:02:42 AM »
Has anyone ever installed a spring relo kit.......do's and dont's..???
Also after the kit is installed what is the biggest wheel / tire combo you can use....and the proper back spacing of the rim......wanna stuff the biggest tires possible....thx
Jason
Offline 360 'CUDA
Re:Spring Relo kiit
« Reply #1 on: January 30, 2004 - 12:04:12 AM »
the recipe that should fit everyones E-bodies
1962 to 1970 B-body (2 or 4 door) 8 3/4 rearend
That is a rearend that has a springseat of 44 inches
center to center and an overall length of 59.2 inches
from brake drum to brake drum
Dana 60's work well too ;D
buy the 2 inch longer offset  spring hanger from Mopar
A-body Super Stock springs or equivalent
10 inch wide wheels with an offset of 5 1/2 inside and
4 1/2 outside
295 / 50s size tires on 15 inch wheels
275 / 60s look interesting too but the drivers side fender lip might need a quarter inch or so trim as
the outside of the tire is closer on that side .
You wouldn't want to shave off your white letters ;)
Offline 360 'CUDA
Re:Spring Relo kiit
« Reply #2 on: January 30, 2004 - 12:18:02 AM »
PS
(that void where prohibited thing REV was talking about)
Slicks are a different story because the sidewalls might
hit the springs so you might want get the 10 inch wheel
with the 5 x 5 offset or even less then that on the inside
