Author Topic: Transmission advice  (Read 1410 times)
Offline MOPAR-or-NoCar73
Transmission advice
« on: December 04, 2007 - 11:18:01 PM »
Hi,
     My next purchase for upgrading my challenger is getting the Keiser automatic to 5 speed manual trans kit. What transmission kit(TKO 500 or TKO 600) would you recommend for a 408 stroker(which I currently do not have)? I figured that a TKO 500 would be good for my 318 that is currently in may car, but if the TKO 600 would be better for the 408 I would like to get that. May main concern is if the TKO 600 would not be a good match for the 318.
May plan is first to buy the transmission and then when I have more money to spend upgrade the motor to a stroker.
Thanks for the help
Anthony
Re: Transmission advice
« Reply #1 on: December 04, 2007 - 11:21:22 PM »
Also, I am most likely going to have 3.23's in the rear since that is what I have already.
Offline Carlwalski
« Reply #2 on: December 04, 2007 - 11:39:55 PM »
Definitely the TKO-600 and in your case I'd go with the 0.82 version. :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: December 05, 2007 - 08:08:58 AM »
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #4 on: December 05, 2007 - 10:42:20 AM »
Thanks. Why do you recommend the .82 over the .64? Would it work well with my 318 for the time being?
Offline Carlwalski
« Reply #5 on: December 06, 2007 - 05:57:50 PM »
The TKO 0.64 IMO gearing is just a little too high (low) for most people who drive there cars in all types of conditions and locations (highway, city, suburban, etc). I made the comparison chart for myself when I was looking. I used 3.23 gears as an example but as you can see the the old TK0-500 is too low a gear, 1st is basically a waste of time and that's using 3.23s in the example.
Not only that but doing the speed limit (65mph) in 5th is too low IMO at 1,700rpm and when you're at 2,200rpm you're way up at 83mph lol If you want to set a land speed record this is great news but in real life it's a complete waste. You need a bit of punch and to keep the engines rpms up a little more than that. Anyhow, check out the chart. I'm by no means a pro this is just what I have learnt and found when I purchased mine.  :2cents:
TKO-500 (0.68) 550hp
3.23s = 3.98 1st gear ratio.
65mph in 5th is 1700rpm.
A lowly 2,300rpm is 83mph.
TKO-600 (0.64) 650hp
3.23s = 3.49 1st gear ratio.
65mph in 5th is an above idle like 1,600rpms!?!
A lowly 2,300rpm would be cruising at 93mph.
TKO-600 (0.82) 650hp (My pick)
65mph in 5th = 2,100rpm Much better.
2,300rpms is better throttle responsive 72mph.
Cheers,
Carlwalski
« Reply #6 on: December 07, 2007 - 11:17:23 PM »
 :2thumbs: Thanks!  :2thumbs:
