Author Topic: 71 duster pro-street  (Read 5205 times)
Offline mytmopar
  • 69 gtx 440 vert-71 chally 340 blown-70 R/T coronet
« on: May 27, 2002 - 01:07:06 PM »
1971 pro-street duster has 360ci bored .40 over with electronic ign, hp annilater and lazershot coil and 11:1 trw flat tops with pro moly rings , solid lifters, lunati 603/318 cam, crane gold rockers, steel crank, stainless valves 4 barrel cast heads #3418915, int 2.080, ext 1.60,block 4 corner decked,pete jackson gear to gear timing, ble print and balance within 1 gram,holley fuel pump with 2x4 reg, weiand tunnel ram with 2 650 holley dbl pumpers.coated headers have parts list and dyno report.dyno'd at 500 hp. has tci 3500 stall, 727 tf with reverse valve body, hurst qtr stick shift, back half'd professionally with 4 link and coil overs, tubbed and narrowed ford 9" with 4.56 gears. centerlines all around with 31x16.5x15 mickey thompsons on back.4 wheel disc brakes all wilwood setup. new paint job lemon twist with stripes. interior is black with racing buckets and 6 pt roll cace padded. also autometer 5" tach with shiftlite. it has ralley dash new carpet, new door panels.car is straight and solid. it was sanded to the metal before paint. has hte best of everything
draws a crowd every where it goes.
will also trade for 70-71 no rust stock cuda PLUS cash. prefer
big block
financial difficulties for me to sell! i will sell for $22,000.  i have 35+ in the car. thanks for the ad
get in, sit down, buckle up, and hold on! see you later, BYE!!
Offline blownduster
  • Newbie
  • I'm a llama!
Re:71 duster pro-street
« Reply #1 on: August 04, 2002 - 11:32:26 PM »
please send me any info/pics you can
Offline mytmopar
« Reply #2 on: August 13, 2002 - 08:42:32 PM »
if you want to see pics of this beauty goto photoisland.com
                                      user name- mytmopar
                                      pw            - duster340
thanks for the ad.
[attachment deleted by admin]
Offline mytmopar
« Reply #3 on: August 25, 2002 - 08:44:14 PM »
 :(you guys had your chance. too late now. i'm gonna keep it.     8)
