Author Topic: Biggest Rim / Tire combo....  (Read 2152 times)
nivvy
« on: January 29, 2004 - 02:22:34 PM »
Anyone know what the biggest rim/tire combo I can run.......Im planning on 15*10 Weld Pro Stars and would have had the springs relocated as well to use the entire wheelwell.....
I currently run 275/60/15's on 8 inch rim with 4.5 backspace
what would be the perfect backspacing of the rim to stuff the whole wheelwell and tire size to use?
thx to all
Jason
Offline 360 'CUDA
Re:Biggest Rim / Tire combo....
« Reply #1 on: February 01, 2004 - 11:38:46 PM »
I wrote this the other day,, in case you didn't see it
here it is again
the recipe that should fit everyones E-bodies
1962 to 1970 B-body (2 or 4 door) 8 3/4 rearend
That is a rearend that has a springseat of 44 inches
center to center and an overall length of 59.2 inches
from brake drum to brake drum
Dana 60's work well too
buy the 2 inch longer offset  spring hanger from Mopar
A-body Super Stock springs or equivalent
10 inch wide wheels with an offset of 5 1/2 inside and
4 1/2 outside
295 / 50s size tires on 15 inch wheels
275 / 60s look interesting too but the drivers side fender lip might need a quarter inch or so trim as
the outside of the tire is closer on that side .
You wouldn't want to shave off your white letters
Offline positraction100
  • I'm a llama!
« Reply #2 on: February 16, 2004 - 06:40:31 PM »
Can anyone tell me a good tire size combination for front/ rear on a 1970 Barracuda. I am running 15x7 rims (Mopar ralleye's). Thanks!
Offline GoFish
  • Who's your daddy?
« Reply #3 on: February 18, 2004 - 07:35:38 PM »
Best tires for a 1970 Barracuda depend on what you want to do with it.  Are you going to throw it around a track like an AAR?  235/60's would work great.  For the strip?  You might want to go to 275's on the back with 8" wheels.
You're probably just looking for a cool look for cruises and such, right?  I've got the same 15x7 rallye wheels as you and have 215/60's on the front with 255/60's on back.  Looks good.  You really shouldn't go bigger than 255 width on 7" wheels.
Mike C.
  • I'm a llama!
« Reply #4 on: February 18, 2004 - 09:08:04 PM »
Just looking for a cool look..Thats all! Thanks for the info. I will most likely use P255/60/15 on the rear and was considering P235/60/15 for the front. Any problems with the front fitting? Thanks!
Aaron
