Author Topic: Getting fuel to my new engine....  (Read 827 times)
Offline burrpenick
« on: December 07, 2007 - 11:12:16 AM »
Finally dropped the fresh 360 engine in my '72 Cuda last night. I've redone the gas tank, installed a new fuel line and was wondering if I should somehow get the fuel up to the pump before I try to fire the motor? I will fill the carb bowl, but figured that it may be a good idea to get the gas at least up to the pump before I crank it. The less I have to turn the motor the better since it has the assembly lube on the critical parts. Any ideas on this and if it is a good idea, HOW CAN I MAKE IT HAPPEN?
GEORGE
currently Moparless
Re: Getting fuel to my new engine....
« Reply #1 on: December 07, 2007 - 11:21:50 AM »
just fill the carb , it will run long enough to get fuel from the fuel tank
« Reply #2 on: December 07, 2007 - 12:51:27 PM »
In my case, it was just barely so.   :grinyes:
Offline burrpenick
« Reply #3 on: December 07, 2007 - 03:08:02 PM »
Any suggestions on how to get some fuel up to the pumb before I hit the go button?
GEORGE
currently Moparless
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: December 07, 2007 - 03:48:19 PM »
Weird idea but you car disconnect the line at the pump and jack up the rear of the car a little to let gravity take it's course (take the gas cap off!) or you can suck it through with a pump, like a mity-vac or something.   :2cents:
Would the additional cranks to get the fuel tot he pump make that much difference in a new engine?  Just curious...  :dunno:  When I put in my new tank it didn't take that long for the engine to start up.
Offline matt63
« Reply #5 on: December 07, 2007 - 04:01:21 PM »
This will work just fine.
Matt in Edmonton
'68 Valiant
