Author Topic: Thoughts on shocks.........Small block car  (Read 715 times)
Offline cuda-cable
  • MOPAR or no car
« on: December 07, 2007 - 12:27:03 PM »
Looking to put new shocks on my Cuda, 340 with headers. Ground clearance is minimal so looking to perhaps put on a shock that has adjustable damping to perhaps control the downward movement of the car over larger bumpsto save the header pipes.  Do we know if this is better than a shock such as KYB'Gas-a-just" unit....thoughts?........thx.
Re: Thoughts on shocks.........Small block car
« Reply #1 on: December 08, 2007 - 02:02:46 PM »
The torsion bar is the device that will prevent the suspension from bottoming out. Increasing the wheel rate is of major importance in a lowered car because you need increased resistance to compressingthe suspension with the reduced amount of wheel travel. The shock simply determines how quickly that bottoming occurs and will not prevent it from happening in all circumstances.
However, there are a number of decent shocks out there. If your looking for single or double adjustables there is QA1, Strange, Be Cool, Addco, Hotchkiss, Bilstein, Belltech, Rancho and more. Prices will range from around $125 to upwards of $400 depending on make, adjustment, range,and application.
« Reply #2 on: December 08, 2007 - 05:06:29 PM »
Edelbrock , Koni , Monroe , most have more then 1 type as well
