Author Topic: Ignition switch madness  (Read 5703 times)
Re: Ignition switch madness
« Reply #15 on: December 19, 2007 - 11:58:00 PM »
with the snap ring removed the upper housing will slide up the shaft withotu a puller
Offline Bearcuda
« Reply #16 on: December 21, 2007 - 06:48:15 AM »
Yeah, in theory I guess. No amount of coaxing will make mine come off. Where can I get this special puller? It looks like that is the only way mine is coming off.
1973 Cuda 440
1971 Javelin SST
Offline Bearcuda
« Reply #17 on: January 01, 2008 - 09:19:47 AM »
Does anyone know where to get this special puller as that seems to be the only way this one is coming off?
1973 Cuda 440
1971 Javelin SST
« Reply #18 on: January 01, 2008 - 11:49:39 AM »
I have never used one
Offline Bearcuda
« Reply #19 on: February 16, 2008 - 07:35:58 PM »
Alright, after giving up on this for awhile I finally got the materials to make my own puller. It worked very well. I was finally able to replace my ignition switch, but alas this doesn't seem to be the whole problem to the car not starting. I'll have to troubleshoot the wiring more. I thought you guys would like to see the puller I made to get the secondary piece of column off, but I also had a question. After putting most of it back together, it seems that the gap between the two pieces of column is too large. I don't have my Cuda here to compare it to (it's in storage at a buddies house) so I can't tell if this is normal or not, but it looks to big to me. It's tightened down all the way. Is this the normal gap?
1973 Cuda 440
1971 Javelin SST
Offline Bearcuda
« Reply #20 on: February 17, 2008 - 09:14:35 PM »
Come on folks, will someone answer my question please. All of you have steering columns to check for me.
1973 Cuda 440
1971 Javelin SST
« Reply #21 on: February 18, 2008 - 01:26:47 AM »
looks reasonably normal to me
« Reply #22 on: February 18, 2008 - 08:52:02 AM »
Mines never been apart, the gap measures aprox. 3/16".
Offline Bearcuda
« Reply #23 on: February 18, 2008 - 12:26:27 PM »
thanks guys
1973 Cuda 440
1971 Javelin SST
