Rusty,
On my Cuda, the A-518 uses the factory slap stick floor shifter. You will have to do a few modifications to the linkage to get everything to work correctly, but the changes are easy kind of self explanatory. The main change is to a shifter linkage bracket that is mounted to the 727 that will not bolt to the A-518. You just need to modify this bracket to mount to the A-518 and everything will fall into place.
